Author Topic: no heat from heater  (Read 1397 times)
Terry_Seyforth
  • Great Yarmouth
no heat from heater
« on: 30 September 2012, 12:24:01 »
Hi I have not had any heat from the heater for about 2 years with winter closing in I must rectify this some how. My friend said try changing the heater control valve, I have done this with no luck, I have tried removing the vacuum pipe on top of the heater control valve and when you swap from hi to low it does suck. I felt the hoses attached to the heater control valve the hose on its own and the hose on the top of the two hoses together are hot but the hose out of the two on the same side ( bottom of the two ) isn't as hot, not sure what that means, also read you should feel the two hoses attached to the bulk head entering the inside of the car, I read that if one isn't as hot as the other it could be the matrix ? .( one isn't as hot ) I am trying to avoid the additional work of changing the thermostat as I am not sure if that is the problem. Is there any tell tail signs that point out what the real problem can be, and if it is the thermostat is it really that bad to change . thank you for any replies . :-\
DOH!!
Re: no heat from heater
« Reply #1 on: 30 September 2012, 12:38:51 »
Hmmm, sounding like a blocked matrix.
Wonder if its worth trying to flush out  :-\
« Reply #2 on: 30 September 2012, 12:47:43 »
... . also read you should feel the two hoses attached to the bulk head entering the inside of the car, I read that if one isn't as hot as the other it could be the matrix ? .( one isn't as hot )  ....
As The Boy suggests, I'd also say your matrix is blocked. One hose is hotter than than the other because you don't have a flw through the matrix, you've got hot water to it, but as there's no water going through it, the exit hose is cold-er. Try your garden hose in both direction through it.
My Dad's Granada hed similar problems. He removed the hoses & then extended them upwards so that he go disolve a dishwasher tablet in there. Although eneded up replacing the matrix in the end (piece of cake compared to an Omega), it did make an improvement
« Last Edit: 30 September 2012, 12:49:36 by Andy B »
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #3 on: 30 September 2012, 13:31:13 »
I've had this problem since we bought the car 8 years ago.  I finally got round to changing the matrix a couple of days ago and boy what a difference, lovely hot air at last.  Not saying this is your problem, but it does sound very like it.  I tried all sorts of other solutions before finally convincing myself that it was the matrix.
There is an excellent comprehensive guide on here to changing the matrix without removing the dashboard for which I must say my thanks, and I have taken some extra photos to clarify a couple of points if anybody wants them.
« Reply #4 on: 30 September 2012, 15:09:21 »
Ask Jimbob if they can be added to the guide :)
Page created in 0.027 seconds with 16 queries.
