Author Topic: car died  (Read 3793 times)
gpenny07931
  • greenock (scotland)
    • omega 2.2cd auto
car died
« on: 30 September 2012, 14:13:37 »
Drove my car earlier and it went fine. Jumped in ther and it refuses to start? Engine turns but just won't start? Any common things to check? Its a 2.2cd auto.
martin42
Re: car died
« Reply #1 on: 30 September 2012, 14:14:27 »
crankshaft sensor????
gpenny07931
    • omega 2.2cd auto
Re: car died
« Reply #2 on: 30 September 2012, 14:20:01 »
Is that easy to get to or is it a big job?
Re: car died
« Reply #3 on: 30 September 2012, 14:21:54 »
Crank sensor on 2.2 is bullet proof, cam sensors fail, but they will start even with it disconnected.
You need to get codes read, do you have a reader?
Has the key stayed intact? Check the little chip is still inside  :y
SteveAvfc.
    • Mv6 2.6 V6
Re: car died
« Reply #4 on: 30 September 2012, 14:26:02 »
Use to have the same problem a while back, found that by re-locking and re-opening the car via the fob fixed it ??
gpenny07931
    • omega 2.2cd auto
Re: car died
« Reply #5 on: 30 September 2012, 14:26:25 »
no I dont have a reader. The key seems fine. Opened it up and all it there and works.
Re: car died
« Reply #6 on: 30 September 2012, 14:32:07 »
Dash lights all coming on? Any of them flashing?
Tried locking & unlocking the car again?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: car died
« Reply #7 on: 30 September 2012, 14:35:58 »
Is it turning over faster than usual? Check timing belt integrity...
Can you hear the fuel pump priming when the ignition is first turned on?
If the immobilizer chip has been lost from the key then the e.m.l. should flash as your trying to start the car.
Re: car died
« Reply #8 on: 30 September 2012, 15:10:29 »
If you keep the starter spinning for about 5 or 6s (no longer than this!!), does it start?
gpenny07931
    • omega 2.2cd auto
Re: car died
« Reply #9 on: 30 September 2012, 15:12:12 »
Still won't start. There's a light flashing with a car and spanner on dash.
Re: car died
« Reply #10 on: 30 September 2012, 15:13:34 »
Ah, immobiliser.
Had the key apart recently? If so, look around where you had it apart, looking for a small bit of black cermaic/plastic...
Re: car died
« Reply #11 on: 30 September 2012, 15:13:52 »
Or try your other key
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
Re: car died
« Reply #12 on: 30 September 2012, 15:16:31 »
Sounds like exactly like what i had on my 2.2, i went through changing sensors etc, in the end it was the ECU. (the code reader was telling me it was the ECU as well !)
gpenny07931
    • omega 2.2cd auto
Re: car died
« Reply #13 on: 30 September 2012, 15:19:47 »
Key seems fine. Still opens and locks car.
Re: car died
« Reply #14 on: 30 September 2012, 15:31:55 »
Is the transponder chip secure in the key
