Author Topic: Wishbone procedure  (Read 2209 times)
a2reed
  • Battersea London
Wishbone procedure
« on: 01 October 2012, 12:08:23 »
I amm fitting new bones and following the guide in the how to section..... One question.. Although i realise not to tighen the front bush until its loaded...surely I can tighten the rear bush while still in the air cant I.???
Re: Wishbone procedure
« Reply #1 on: 01 October 2012, 13:41:10 »
Yep
a2reed
  • Battersea London
« Reply #2 on: 01 October 2012, 14:11:34 »
and if I then roll the car back and forward  and then up some ramps I can do the front one loaded can't I ?????
« Reply #3 on: 01 October 2012, 14:16:00 »
Yep. Although the bumper will foul the ramps.
Jack up and place cramps under...? Bounce the suspension on the front and the ramps should slide to allow the suspension to settle.
a2reed
  • Battersea London
« Reply #4 on: 01 October 2012, 14:18:19 »
Thanks guys ...big help
  • Auckland
    • Mazda MPV
« Reply #5 on: 01 October 2012, 15:29:08 »
I use a couple of short (3') lengths of scaffold board to allow me to drive up on to the ramps without fouling the bumper.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #6 on: 01 October 2012, 16:37:26 »
Started to do mine fitted one also the drop link now car is sitting high. Do I remove it and start again or just loosen bolts or what?
« Reply #7 on: 02 October 2012, 00:33:06 »
if you tightened the bolts wheels hanging/off the floor, yes undo the front bolts and tighten wheels loaded.
But have you driven the car back and forth to allow the wheels to settle to the right track...?
Or is the drop link the wrong one/too long?
Page created in 0.048 seconds with 16 queries.
