Author Topic: confused crank?  (Read 1403 times)
sw3en3y
confused crank?
« on: 02 October 2012, 20:08:04 »
have had a fault where car runs fine then feels as if its missing and emission light starts to flash (pedel test 0560 voltage error) tonight driving home emission light starts flashing and car runs rough then light stays lit. normally turn off and on again and its fine not now now getting crank sensor and misfire cylinder 2 fault codes, can a faulty crank sensor cause the above errors?
Re: confused crank?
« Reply #1 on: 02 October 2012, 20:13:54 »
Check for oil in plug wells, and state of Coil Pack
sw3en3y
Re: confused crank?
« Reply #2 on: 02 October 2012, 20:15:29 »
what would cause oil to get in plugs? and is this a major problem?
Re: confused crank?
« Reply #3 on: 02 October 2012, 20:16:42 »
Blocked breather system resulting in camcover gaskets leaking
sw3en3y
Re: confused crank?
« Reply #4 on: 02 October 2012, 20:19:30 »
just really annoying only had the car a week and all these problems started sunday coming home from shopping car started to feel rough and then flashing emmision light, turned engine off and then on again and all was fine just fault code for voltage and then the above tonight
Re: confused crank?
« Reply #5 on: 02 October 2012, 20:22:49 »
sw3en3y
Re: confused crank?
« Reply #6 on: 02 October 2012, 20:28:13 »
no was waiting for a mobile mechanic to come out as i don't have a volt meter, he is now coming out tomorrow. I was just hoping to understand if a faulty crank sensor would cause these symptoms so when mechanic turns up i know if he's trying to get me to part with unnecessary money for jobs that don't need doing.
sw3en3y
Re: confused crank?
« Reply #7 on: 04 October 2012, 22:21:33 »
Car was fixed today, coil pack was oozing a gel/oil substance causing it to overheat and stop working on cylinder 3 and throw up all the fault codes. So am a very happy person this evening
Thanks again for all the advice.
