Pair of Headlamp trims, PFL or MFL
Started by Shackeng, 03 October 2012, 18:12:17
Shackeng
Wanted, as above, the plastic bits that fit underneath and round next to the grille. I think they are the same on both mfl and pfl. (Waits for RobG to confirm. ::) ::) ::))
Quote from: Shackeng on 03 October 2012, 18:12:17
Confirmed ;D
I_want_an_Omega
Do you need them with or without the holes for headlight washers?
Shackeng
Agemo
Suppose you are sorted now, but I have a nearside one in black, no holes. I may have another in the garage, will check tomorrow.
Shackeng
No still looking, any colour will do thanks. :y
I_want_an_Omega
I have a pair in silver, but with holes. If you were going to spray them another colour it would be easy enough to fill the holes in and then spray. HTH - Rob
Shackeng
Quote from: Lincs Robert on 09 October 2012, 10:08:06
Thanks Rob, I have a couple of Elite ones with holes I can use if necessary, ( I could fill these) but would to prefer to replace my damaged plain ones, I only really need the n/s one, although a clip is broken on the o/s also. Or I could fit elite h/l jets (like rocking horse manure apparently) and possibly the whole headlamp washer kit. I might go to stealers as it can't be that expensive. :y
I_want_an_Omega
Quote from: Shackeng on 09 October 2012, 12:01:12
I'm sure the trims cant be expensive - but the headlight washer nozzles are almost £50 each new  :o
Shackeng
Just got a PM about some trims, so hopeful. :y
tigers_gonads
Just seen this thread  :-[
I know I have one pair (my spare) but might have a 2nd pair of a scrapper  :-\
Give us a day or 2 too have a dig around  :y
The Red Baron
got a pair or green ones from a gls here, wish you had said when you was up.
Shackeng
Quote from: The Red Baron on 12 October 2012, 22:55:06
Thanks Jon, I said I could fill the holes in the Elite ones you gave me, but obviously it is easier to fit the blank ones, which I didn't realise that you had. D ;D ;D :y
The Red Baron
Quote from: Shackeng on 13 October 2012, 13:38:24
if you cant get hold of any, give me a shout & i will dig them out for you. :)
