wrong fuel
Started by paul.lovejoy, 03 October 2012, 18:46:31
paul.lovejoy
the old chap that is currently working for me put petrol in his diesel van by mistake last weekend £20 worth
the van is a W reg 2.8 movano. he was advised to stick £60 of diesel in and told it would eventually work its way out.
The van used to pull like a train but at the moment is slow to accelerate although it is not missfiring at all.
any advice please
waspy
They did an experiment on a motoring program a few years ago. They drained the tanks, put petrol in a diesel & visa versa.
They drove them till they conked. Filled the tanks with the correct fuel & all was good.
Brim it with diesel & it'll be ok :y
£20.00's only 3 gallon & in a twenty gallon tank. I wouldn't worry :)
Darth Loo-knee
Speak to Lazytinker it's his job Paul :y
Someone call? ::) :D
Paul, I'll PM you my number ;)
Darth Loo-knee
Quote from: Lazydocker on 03 October 2012, 19:03:34
I hate saying this as you know... but your a good lad.. although you did fallout of the ugly tree, hitting every branch  :-*
Quote from: Darth Loo-knee on 03 October 2012, 19:06:00
No, Dazzle, you are confusing the useless Cripple with yourself :P
paul.lovejoy
PM recieved mucho grassy arse :y :y
martin42
try millers diesel addative,works wonders  :y
I still look handsome stood next to you though Dazzle ;) ;)
Quote from: Pete. on 03 October 2012, 18:53:46
On an older diesel engine I'd agree with you but on a modern, common rail system even as little as 10% petrol in the system can cause damage ;)
Modern, common rail engines use a high pressure pump with very small tolerances and rely on the lubrication from the diesel. Putting petrol, a solvent, through them is never good for them ;) On some makes you can get away with more but, unfortunately this isn't one of them  ::)
The fact that it's still starting and running means he will probably get away with filling back up again and it will eventually clear. I'd also advise looking for a fuel system additive that lubricates (but doesn't clean!) the fuel system but I'm not aware of one that is available to the public. Ours is specially formulated for us and unique ;) It's also expensive ::)
waspy
Paul & Paul. Please don't keep it to yourselves as to what to do :) :)
waspy
#10
Quote from: Lazydocker on 03 October 2012, 19:34:21
Quote from: Pete. on 03 October 2012, 19:35:10
Well that was quick ;D ;D ;D ;D
Would two stroke oil be ok as the lube you talk of. I use it in my DTi :y
Loverlength... Empty your inbox ;)
Yep... A bit of 2 stroke would be better than a kick in the nads :y :y
Not trying to be secretive, although I have quoted Paul a price which is why I've done it via PM ;)
Incidentally, I'm not advising he has it drained as they have managed to use most of the fuel in the tank anyway ;)
paul.lovejoy
Quote from: Lazydocker on 03 October 2012, 19:40:01
i have emptyed my self now :o :o took a while :y
the alarming man
Quote from: paul.lovejoy on 03 October 2012, 20:09:24
yeah its all that breakfast you eat..millwall will back me up here :y
