Author Topic: MV6 Front Seats PFL and FL Identification?  (Read 1639 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 04 October 2012, 12:32:44 »
Ok, I know on the clothe type you can tell the difference due to the clothe being a different material on the PFL and FL.
My question is on the Leather flavour, is there an easy to way to confirm which is PFL and early FL (very late FL had a different grain) , ie part no's or just by looking at them?.
Seem to remember something about the Head rests aren't swappable, not confirmed, but still need to know which seat is which (Having a sort out).
Thanks.
twiglet
  • Norwich, Norfolk
Re: MV6 Front Seats PFL and FL Identification?
« Reply #1 on: 04 October 2012, 15:00:53 »
Prefacelift (94-97). Mechanical pretensioners, simple heating, no active restraints, no side airbags
Minifacelift (98-99). Pyrotechnic pretensioners, simple heating, no active restraints, side airbags
Facelift (00-03). Pyrotechnic pretensioners, advanced heating, active head restraints, side airbags
Feature                      PFL             MFL               FL
Belt Pretensioners        Mechnical     Pyrotechnic    Pyrotechnic
Side airbag                 No               Yes               Yes
Active Head Restraint   No               No                Yes
Seat Heating              Simple          Simple            Advanced
zirk
  • Epping Forest
« Reply #2 on: 04 October 2012, 15:20:30 »
Thanks James, just relised I made an error, forget PFL, I really ment MFL and FL :-[
So to ask the question again,, just  by looking at them, ie, not in the Car, identifying MFL and FL MV6 leather front seats.
Thanks again  :-[ :y
« Reply #3 on: 04 October 2012, 15:24:53 »
Pop the rear panel off, should be a date sticker on the airbag assembly :-\
Mfl shoul be upto mid '99, fl post '99 at a guess :y
I_want_an_Omega
« Reply #4 on: 04 October 2012, 15:50:32 »
There is an easier way:  8)
MFL MV6 seats only have the following electrical connections:
Side airbags (2 thin wires)
Seat belt pre-tensioner (2 thin wires)
Heated seat (2 thick wires)
Motor supply (2 thick wires)
So, that's a total of 8 wires.
FL seats have more wires for the heated seat connections.
So, if it's 8 it's a MFL, more than 8 a FL  :y
zirk
  • Epping Forest
« Reply #5 on: 06 October 2012, 16:14:33 »
Just had a look, 2000 FL also has 8 wires, although 2 of the connectors where pink inside?
zirk
  • Epping Forest
« Reply #6 on: 06 October 2012, 16:15:24 »
Missed this will have a play tomorrow. ;).
