WTD: Few 3.2 Parts!
Started by Stallion, 04 October 2012, 21:26:13
Stallion
Hi guys iv got a 2001 3.2 Elite Auto. and after a centre armrest preferably in good nick? As mines the top clip has broken! Also mines has the 2rear heat switches on the back of the armrest (if that makes any difference)
Day by day my braking distance needs to be increased as the spongy feel still there and has been from day 1? I know thats normal but iv tried bleeding the hoses etc and still seems weak hence hoping a breaker here can provide me a lucas brake master cylinder ( last hope trying to get rid of the sponge feel)
And also maybe after a PAS unit, as mine seems to have a mind of its own and have to fight with it when it comes to parking??
Have checked both brake and pas fluid, both topped and havent been loosing any, colours a little darker then new fluid, but i doubt that would make all that difference!
I will have a master cylinder and PAS pump if you need them both,but would need advice as to whether they are the same as the ones on your car Sam.Ask on the forum if your not sure. :y
Stallion
Master cylinder should be OK, advisable to check bore size (cast into the housing) normally 25/20 or 25/25.
Stallion
Saw this number directly behind the brake fluid top up reservoir, saw 8 digits followed by 2 capital letters. Or do i have to find another way to view the bore size?
Will have a look at mine tomorrow Sam,see if we have the same markings. :y
Brikhead
I have a centre armrest in very good condition.
Quote from: Stallion on 04 October 2012, 21:26:13
I also have a 2.6 master cylinder and power steering pump available if 'Albitz' can't sort you out.
The master cylinder In have is marked 25 on the top behind the reservoir,2017 - 1 - 23 on the underside.Im still none the wiser if thats any good tbh,and still havent a clue about the PAS pump. :-\
Stallion
Any info on the 3.0 PAS pump being fitted onto a 3.2 Albz, whether it would fit or there are actual differences..  :y
Just posted after your post in "what have you done" thread Sam. :y
Might be worth starting a new thread with the question ?  :-\
