Author Topic: 3.0 - 3.2 part differences??  (Read 1884 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« on: 04 October 2012, 21:52:55 »
To anyone whos played around with a 3.0 and a 3.2! Would the master brake cylinder and PAS unit from a 3.0 fit into a 3.2? Any advice will be appreciated and the winning advisor will be rewarded with a packet of nobbys nuts sent via post!  :y
Re: 3.0 - 3.2 part differences??
« Reply #1 on: 04 October 2012, 22:38:33 »
I have a feeling the master cylinder changed when vented rear brakes came in.. although it might have been with the 4 channel ABS system. There should be numbers indicating the bore sizes cast into it.
As for the PAS system, I think the pump might be different on a 3.2 versus the 3.0 but someone who knows for sure will no doubt be along too.
Stallion
  • Romford
« Reply #2 on: 04 October 2012, 23:12:25 »
Thanks for the info KW! Im pretty sure my rears discs are vented   :(
« Reply #3 on: 05 October 2012, 09:46:10 »
I think there are 2 numbers on the side of the MC, giving the diameters of the 2 cylinders. That should tell you if they're the same.
