Pages: 1 ... 20 21 22 23 24 25 26 [27]   Go Down
Author Topic: Oh no, what have I done .... ?  (Read 54923 times)
Re: Oh no, what have I done .... ?
« Reply #390 on: 22 November 2012, 20:18:55 »
Superb mate.Sorted at long last. :y
If your confident all is well,it would be worth changing the belt & tensioners,and making sure the timing is absolutely perfect.
Well done. :y
« Reply #391 on: 22 November 2012, 20:32:44 »
Fantastic news   :y  :y  :y  :y
How on earth did the timing slip though?  :-\
Bet you are chuffed now though :)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #392 on: 22 November 2012, 20:37:31 »
Well done. :y
Cheers Albs, but I can't really take any of the credit - it was all OOF  :y
The only thing is that I now know a lot more than I did before - hopefully that's a good thing  :D
Thanks Mark, and it must have been that stupid washer  >:(
Can't believe it, but well chuffed now  ;)
  • Auckland
    • Mazda MPV
« Reply #393 on: 22 November 2012, 20:43:54 »
I wonder where it is now? Hiding inside the aux belt pulley perhaps :-\
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #394 on: 22 November 2012, 20:50:16 »
well i thought you were gonne beat  "so what have you done to your car today" ;D ;D
« Reply #395 on: 22 November 2012, 20:50:37 »
That a good point, full strip down maybe in order, make sure it's not going to cause a problem again.
« Reply #396 on: 22 November 2012, 20:50:47 »
I did something not that dissimilar with a foreign object and a cambelt a long time ago. I lost the oil pressure on my Chevette HS and being young and gung ho,I dived in and completely stripped the engine and then commenced on a full rebuild,which ended up taking severl months,mostly due to VX dealer constantly ordering in the wrong parts,and partly due to the fact I had never rebuilt an engine in my life.
Eventually,just before Christmas I got it all back together and running nicely,apart from a not too serious leak from the rad.
Swmbo was eager to get taken to a supermarket 10 miles away to do Christmas shopping,so of we went. On the way back the engine started to get pretty hot,so worried about the very expensive alloy head (over £1000 30 years ago !) I pulled into a layby to let it cool down a bit and then add coolant.
I got a bit impatient and decided to take the rad cap off to help it cool down quicker.The cap shot up,hit the underside of the bonnet and came back down and jammed between the cam pulleys,instanly slicing through the brand new cambelt.
I left the car where it was all over Christmas,which wasnt the happiest,due to self disgust and also worry about the car.
Towed it back home and took the head off again.Two new inlet valves and a new cambelt required,and all was well. ::)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #397 on: 22 November 2012, 20:57:41 »
Me too  :-[
There was one found apparently on my drive. I wasn't aware at the time, but ultimately I didn't fully realise how it could cause any problems. If you remember, I initially looked for it as I thought it may be stuck somewhere, thereby causing the rattle. Not for a second did I think about the belt slipping as a result, and not having been at the timing during the work undertaken, I didn't appreciate the significance  :(
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #398 on: 22 November 2012, 21:10:34 »
I was spot on then, have seen this problem loads of times even snapped up the odd bargain on ebay with same fault, all depends on how long / hard the engine.has run in this condition whether or not damage occurs, glad u got it sorted
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #399 on: 22 November 2012, 21:14:28 »
Yes mate, thanks very much  :y
I should have spotted it sooner, but hey ho  ::)
« Reply #400 on: 22 November 2012, 23:05:03 »
What a saga - glad you're sorted now mate.  Full marks to v6man54deg :y :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #401 on: 22 November 2012, 23:14:06 »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #402 on: 24 November 2012, 18:53:30 »
Can we all stop looking for your post on this subject it was the first thing I looked at evertime I switched on and I am sure a lot of others did the same. So glad you got there in the end and I am sure that the support you got from OOF helped you to press on and get a good conclussion. :y
Pages: 1 ... 20 21 22 23 24 25 26 [27]   Go Up
