Pages: 1 ... 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27   Go Down
Author Topic: Oh no, what have I done .... ?  (Read 55360 times)
0 Members and 3 Guests are viewing this topic.
Re: Oh no, what have I done .... ?
« Reply #300 on: 11 November 2012, 12:19:28 »
I'm hoping Jonny is going to post shortly that following replacement coil packs its working, fingers crossed  :y
« Reply #301 on: 11 November 2012, 14:06:12 »
Yeah , feel sorry for him ... he must be ripping his hair out  :( Hope you make some headway with it  ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #302 on: 11 November 2012, 15:40:17 »
Sorry guys, no news yet. Changed the nearside pack as it was still showing misfire on 4, but the battery's flat  >:(
Charging it now so should know later  :-X
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #303 on: 12 November 2012, 11:47:05 »
Replacement packs have made no difference  :'(
Need to get the codes cleared and see what shows up.
I'll need to start looking elsewhere now though, as providing the packs are ok, then I'm not sure it's ignition based problem.
« Reply #304 on: 12 November 2012, 13:08:09 »
Bugger  :(
I double checked, I sourced them from Elite Pete, known working when he removed them. At a loss now as to what suggest  :'(  :-\
« Reply #305 on: 12 November 2012, 13:21:56 »
The coil packs never were going to solve it, it was lottery odds.
Did you do a compression test?
If I get chance, I will re-aquaint myself with the wiring diagrams now I am back from Brazil
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #306 on: 12 November 2012, 13:25:39 »
Me too  :-\
Back to the beginning I think. I can't see it being anything to do with the stat, unless the b bolt and engine mount plate can foul anything in that area? Don't really want to disturb it again as the coolant seems ok, etc.
I can't feel or see anything trapped in the cam covers, and although I don't really want to remove them again (I did remove and inspect at the start of this) I may have to. I have had the plenum and inlet off and on several times and don't believe I could be doing something wrong in that respect on every occasion?
There's nothing to the sandwich plate either, providing all seals are present.
Suppose I may have to inspect the timing again, ensuring tdc, though I don't believe the problem lies there. It would just be something else to rule out ...... again!
Tried a garage with no joy. I guess Vx might just be the same, only more expensive  :-\
Compression test too I think, just to check.
Although I don't understand engines, etc I did think the replacement coil packs were the answer  :'(
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #307 on: 12 November 2012, 13:27:56 »
Sorry, missed this!
I'll need to do the compression test, and thanks.
Car still starts perfectly, and runs without much ado. If it ran perfectly but was noisy, then I'd consider lifters, but I think there's more to it than that .....
  • Auckland
    • Mazda MPV
« Reply #308 on: 12 November 2012, 21:57:49 »
If it happened after you did the work then I still think that chances are it was something you touched :-\ (think about every electrical connector and vacuum pipe you touched)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #309 on: 12 November 2012, 22:12:18 »
I had initially moved away from that idea. Partly because of the noise, and as I thought I had checked everything.
I agree with you though, that its just too coincidental, and I need to retrace my steps again.
If only I had an idea  :-\
« Reply #310 on: 13 November 2012, 09:05:45 »
Breather pipes on in right order?  :-\
« Reply #311 on: 13 November 2012, 09:20:21 »
Do make sure you have not connecetd the gearbox breather to the breatehr bridge by mistake and left the engine breather dangling.
Is there a loudish sucking sound from any area?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #312 on: 13 November 2012, 10:16:30 »
Think so. The fl has the distinction of different sizes for dummies like me!
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #313 on: 13 November 2012, 10:19:57 »
No sucking that I can hear, particularly over the other noise.
Going to strip it back down to the stat again, as far as it was initially, in the event that I can find something I may have disturbed though not been specifically working at. Fairly confident in putting the plenum and inlet back together and don't think I've made any mistakes there. I'll check the breather box and the individual injectors too, though didn't really want to upset them.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #314 on: 13 November 2012, 10:49:29 »
Right. Down as far as sandwich plate. No visible obstructions. Don't see any point really in removing it?
Gearbox breather loose. Large and small breather pipes connected to the box. No obstructions or anything to o/s cam cover.
Pages: 1 ... 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27   Go Up
