Author Topic: How Remove : Parking lights stay on if blinker switch on ( German wiring )  (Read 3949 times)
omegafin
  • xxx
I think this is only in German Omegas ? so if I left blinker switch on left or right side's parking lights stay on. In sunlight you won't notice it so I have had flat battery 2 times  :(
How to remove this option ?
Oops this should be in  Omega Electrical and Audio Help
Moderator please move this ...
« Last Edit: 06 October 2012, 16:58:34 by omegafin »
No, we have this feature too  :y
Indicator always self cancels by time I intend to park, pulling onto a drive or into a car park say, i've never found it a problem.
Not sure how/if it can be disabled  :-\
Don't think it can be disabled  :-\ Been standard on Vauxhall cars for years ;)
omegafin
  • xxx
It won't cancel , parking lights were still on and I parked 3 hours ago  >:(
I have read  somewhere that some wire must cut ??
it's been discussed here a few times ............... you can modify wiring somewhere to disable it. As said though, I've never had a problem with it. Also, the lights on buzzer operates in facelift cars when they're on.
omegafin
  • xxx
buzzer works but not in this situaton.....
Disconnect the black wire at pin #3 on indicator switch
but if it would if the car was a facelift  ;)  ;)
omegafin
  • xxx
It is Facelift Opel Omega 2.5 TD 2000
Sorry! I'd always been under the impression that facelift cars had the lights on buzzer on the parking lights too.
Never had a facelift Omega though.  ::) ::)
Nope,not on mine.It often happens to me as I park in my drive and the indicators dont self cancel.If I forget to cancel them manually I leave the car with the parking light on.Buzzer doesnt sound.Its a pita,so when I get around to it,I will foloow up RobGs suggestion.
Or even follow :P
omegafin
  • xxx
My buzzer works if i put parking lights on by light switch. But in my case indicator switch bypasses
the buzzer .
I will cut the black wire .
Thanks Rob  :y
No mate - buzzer only works if light switch on, same as on mfls.  No buzzer if "parking" light on.
rob in gib
  • Plymouth
    • Jaguar S type 3.0
I know it does not help the OP, but my buzzer always sounds when parking lights on and door open.
sorry meant to to say i have facelift model
Just chilling in the sun. I wish back in the rain like everybody else
