Spanner light gone.
Started by 2boxerdogs, 06 October 2012, 20:57:37
2boxerdogs
Bulb still comes on with ignition so bulb ok!! The car used to go into limp mode when spanner lit up , as i said since timing belt done no more problems. The handbook suggests a fault in the alarm system, and advises to switch off & restart to reset the system .
Quote from: Tilbo on 07 October 2012, 13:33:52
Wonder if cam sensor wasn't seated right, and this was sorted when doing cambelt. IIRC, same bolt that holds camcover in place on 2.2 holds cam senosr in place
Quote from: TheBoy on 07 October 2012, 18:26:50
Nope ;)
Quote from: RobG on 07 October 2012, 18:29:29
Nope ;)
I made that mistake, sheared off the bolt  ::)  :'(
There is actually a tiny little bolt which holds the sensor, its right up in between the two cams  :)
Nope ;)
I usually refuse to work on 2.2s (and 2.0s) ;)
tigers_gonads
If it ain't broke, don't fix it  ;)
jimac
When my cam sensor was failing simply disconnecting and reconnecting it would "fix" it for a week or two.  That eventually became a day or two until I replaced it.  I guess that just disconnecting it has settled it for a while, but it will be back.
