Spanner light gone.
Started by 2boxerdogs, 06 October 2012, 20:57:37
2boxerdogs
Since the spring the spanner light has been coming on fairly often in the 2.2 estate, switching it off & restarting has always cleared it. Last weekend had a new timing belt kit fitted & new water pump , since then no spanner light problems , my mechanic said that  the one he removed appeared rather slack, could this have been the cause I wonder.
The cam sensor which sits behind the two cams, can cause spanner light to be on if faulty. The timing must have been way out though!
its worth checking its been done right, its easy to check the timing. Lug on bottom of crank pulley should match lug in engine block
Stallion
Just thinking if the timing was out wouldnt that bring up the EML light instead of the Spanner light?? I always thought the spanner light represented servicing  :-\
Quote from: Stallion on 07 October 2012, 00:09:22. I always thought the spanner light represented servicing  :-\
Nothing to do with servicing, the spanner is emissions related.  ;)
Gaffers
Quote from: Guffer on 07 October 2012, 06:23:43
I bet it's the bulb  ;D ;D ;D
+1  ;D
That reminds me, I should probably replace mine ::)
Quote from: Andy B on 07 October 2012, 01:41:43
Nope. "Engine" light is emissions. "Spanner" light flags a fault
Quote from: RobG on 07 October 2012, 11:15:27
I got the first bit right .......  ::)  ::)  ::) I don't have a spanner light  :y :y  :y
Quote from: Andy B on 07 October 2012, 11:17:19
The superior 3.0l engine doesn't need one :y
Quote from: TheBoy on 07 October 2012, 11:24:02.....
;D  ;D  ;D  ;D  ;D  ;)
Perhaps not, but it could perhaps do with a rust gauge and a coolant pressure sensor in each head ::)
Quote from: ex taxi al on 07 October 2012, 11:27:13
Not noticed too much rust on my engine ;)
Was thinking more for the rest of the far superior (at rusting) bodywork ::)
Quote from: ex taxi al on 07 October 2012, 11:30:27
Ah, yes, the FL doors are better. Although wheelarches are still weak  >:(
Considering lining the whole wheel arch with epoxy :-\
But we digress ::) check the bulb :y should come on with the ignition :y
