Author Topic: Throttle lube  (Read 1103 times)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Throttle lube
« on: 07 October 2012, 00:15:55 »
Hi peeps, can anyone recommend what sort of lube I should use for my throttle cable and bodies? I've had them off loads of times obviously when cleaning and doing work. I think the TBs are sticking a bit, which is annoying when pulling away due to it being automatic. Will a light GP oil be ok? Oh, and grease for the cable, the spring bit? Thanks peeps.
TC and BnQ Trade holder.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Throttle lube
« Reply #1 on: 07 October 2012, 00:28:56 »
TB's rarely stick, as the spring is too strong, unless its lose, if so clean with Carb Cleaner, chances are your ICV needs cleaning.
Chris. ;)
« Last Edit: 07 October 2012, 00:33:33 by zirk »
