Author Topic: Radiator change for a 2.2cdx  (Read 3511 times)
nchgas
  • barkingside essex
    • 51 vauxhall omega 2.2cdx
« on: 10 October 2012, 11:24:19 »
Hi can anybody help me please
how difficult is it to replace a radiator on a 2.2 cdx is there a step by step guide as no manual was produced for this car by haynes
Any help greatly appreciated
Re: Radiator change for a 2.2cdx
« Reply #1 on: 10 October 2012, 12:23:39 »
Welcome to the forum.  :y :y
The manual for a 2.0 will be good enough to guide to in changing your radiator.  ;) ;)
nchgas
  • barkingside essex
« Reply #2 on: 10 October 2012, 12:26:48 »
Hi Andy
Thanks for replying, sorry to sound like a div but where can i locate this manual
Thanks
« Reply #3 on: 10 October 2012, 12:28:55 »
Hi Andy
Thanks
Halfords or eBay (http://www.ebay.co.uk/sch/i.html?_trksid=p4340.m570.l1313&_nkw=haynes+omega&_sacat=0&_from=R40;) ;) or other local motorfactors
nchgas
  • barkingside essex
« Reply #4 on: 10 October 2012, 12:35:15 »
Thanks very much
twiglet
  • Norwich, Norfolk
« Reply #5 on: 10 October 2012, 13:08:24 »
Removal of radiator also covered as part of this guide...  :y
http://www.omegaowners.com/forum/index.php?topic=90559.0
philsteward
  • Leeds, West Yorkshire
    • 2001 2.2CDX Estate LPG
« Reply #6 on: 10 October 2012, 15:14:58 »
Removing the rad is relatively easy.  Did this on mine a few weeks ago and only took me less than 2 hours to remove, refit and refill coolant.
You obviously do not need to worry about any trumpets as you car doesn't have them!
I think I am correct in saying that the ATF rad is a separate unit on your car, it is on mine, and it sits in between the condenser and the coolant radiator. I did not disconnect the ATF pipes, after removing the air box and easing out the routing of the pipes, I found I could move the ATF radiator enough to get the coolant radiator out from underneath the two metal pipes going to the ATF rad.  It might be easier to just remove the ATF pipes, especially if your auto box is due a level check anyway, mine had just been done!
Other than that, once you have removed the fan, 3 bolts in a triangular layout, that will just lift out.  Then work down each side of the radiator and under the 2 bolts and associated rubber hoses. Then there are two bolts at the top at the front which hold the ATF rad to the coolant rad, and once you have removed the spring clips at the top, it should jiggle out!
Do remember to remove the electrical connections to the radiator.
Best of luck, HTH
