Author Topic: Brake pads  (Read 2294 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Brake pads
« on: 11 October 2012, 13:29:07 »
Any viewes on brake pads made by Pagit, Eicher,Bosch.
Re: Brake pads
« Reply #1 on: 11 October 2012, 13:49:01 »
I think generally the view is probably "Why bother when TC pads are so cheap?" (Something like £15 for a set of fronts).. unless you muller the brakes like TB/CG..
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Brake pads
« Reply #2 on: 11 October 2012, 14:59:50 »
Sorry I should have said that these pads are for my other halves Volvo. And no rude remarks about Volvas
Re: Brake pads
« Reply #3 on: 11 October 2012, 15:10:42 »
Ah, in that case - Pagid make some good pads (they also make some rubbish) and I've no experience of the others :)
Re: Brake pads
« Reply #4 on: 11 October 2012, 17:03:25 »
As said, all manufacturers make pads at both ends of spectrum.
IMHO, unless she drives it particularly hard you won't go far wrong picking up a known brand set from a local motor factors or online supplier.
Re: Brake pads
« Reply #5 on: 11 October 2012, 19:28:01 »
As Kevin Wood says, all "branded" pad makers make a good range and a shite range. The factors generally stock the shite ones, and say things like "Mintex make good pads", but neglect the "but these are their shite ones" bit ;D
Re: Brake pads
« Reply #6 on: 11 October 2012, 19:28:29 »
I use TC ones on teh Silver Bullet.
Re: Brake pads
« Reply #7 on: 11 October 2012, 20:24:50 »
Ah, it's just Chris that doesn't like them, then? I couldn't remember ;)
Re: Brake pads
« Reply #8 on: 11 October 2012, 21:41:53 »
Pretty certain he has TC currently. His problem is his psycological problem with copper grease ;D
Re: Brake pads
« Reply #9 on: 11 October 2012, 23:28:07 »
Try Volvo :-\ most manufactures offer parts at a reduced price for cars over 4 years old, always worth an ask, as genuine parts often last better, so if only a couple of quid more than pattern ones, much better value :y
Obviously if they're 4 times the price, probably best to go pattern :-\
Re: Brake pads
« Reply #10 on: 12 October 2012, 15:40:30 »
nope, oe! If a little cooked last time you drive it. Current week point seems to be the discs. Ebc vented now warped to buggery.
Re: Brake pads
« Reply #11 on: 12 October 2012, 15:41:27 »
Sorry, not vented. The dimpled grooved ones.
