Windscreen trim
Started by Raymienets, 13 October 2012, 18:23:52
Raymienets
Looking for rubber windscreen trim from a 2.2 if anyone has one lying about or knows someone who is breaking one. PM me please
If no joy they are readily available from VX, not too pricey :y got one and the frame when I had a new screen fitted in July :y
Just looked and the rubber and all 4 parts of the frame that it clips into were £49 + vat, nothing was over £15 individually :y
Just to add the design was changed at some point, so if you need to change the frame you will need to buy all four sides and also the frames fitted by replacement windscreen peeps can be different to both the Vauxhall designs :y
Raymienets
This gets more confusing. The one I need replacing is in one piece and only goes down sides and along top, That fox has a lot answer for when it decided to have mine for dinner.
Right, I've dropped a bit of a block :-[
Original design: rubber trim x2, 1 top and both sides, 1 across bottom edge. plastic frame x2, same as rubber.
Later design:  rubber trim x2, 1 top and sides, 1 across bottom edge. plastic frame x4, 2 sides, 1 top, 1 bottom.
Only the rubbers are interchangeable :y
Pattern frames supplied by winscreen frames vary, but usually depend on the rubber being reusable.
Visible differences between two cars could be down to the various frames used and also the actual position of the glass depending on whether the screen is original/replaced properly in the correct position/just thrown in.
Either way the trims are available :y
Raymienets
Quote from: ex taxi al on 13 October 2012, 21:02:46
Cheers
Raymienets
Cheers
Quote from: Raymienets on 13 October 2012, 22:02:56
Cheers
