New member with depressing fault code issue
Started by GrpB Tom, 14 October 2012, 18:15:22
GrpB Tom
Hi everyone,
New to the group and having problems with a 2001 3.2 Elite.
Main issue is that it keeps conking out on me! Have run a diagnostic and it comes back with 0650 code which I expected as a bulb has blown on the instrument panel. It did register problems with the Cats but have replaced the whole system and that code has not resurfaced.
Of interest, is that just prior to conking out there is a noticeable downshift thud from the gearbox - its not severe but heavier than normal. Also the general 'feel' of the car has deterioated - not so much power, gear changes more often than before and acceleration not so sharp.
The engine has been regularly serviced, The transmission hasn't been touched - ever! Thinking problem lies there.
Did the dianostic on that and came back with 'incorrect ratio' but removed the coil packs (cylinder 5+6 full of oil) and cleaned the sparks, tested it and the code did not reappear. Confused? Oh yes indeedy!!!
Any help would be great.
waspy
b4ndit
noel
grain.ben
Jusme
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
flyer 0712
x25dt
BlueBridge
Jon
Stallion
