Author Topic: O/S Exhaust fanimold gasket done ..........  (Read 1583 times)
I_want_an_Omega
« on: 15 October 2012, 14:50:32 »
Well, all done with a pal of mine last weekend and the car has done about 700 miles since. The job wasn't as bad as I was expecting TBH. Just took loads of stuff off for ease of access. Yes, it was time consuming - especially with all our tea breaks.
All the manifold studs bar one came out dead easy, the other one was very solidly fixed in place so we left it there & used it again. It was the front one - up behind the tensioner.
The gasket itself didn't have any breaks - but there were signs of a blowpast right next to the rear section. Also took the opportunity to totally remove the O/S SAI pipe & fitted very short stub pipes that had been welded up. These aren't even visible now from above.
It was interesting looking at the manifold casting as the SAI connections route straight through  the manifold into the head - so the SAI air goes into the head and then into the exhaust - not straight into the exhaust. This isn't quite what I was expecting & I wonder why they did it that way - I guess there is a reason as it's a more complex routing than straight into the exhaust gas stream.
Was especially pleased to see that the breathers were spotless and that the coolant had no nasty sludge.
Many thanks to Amba for all his comments and encouragement on this little job - I hope I never have to do the N/S as that looks much tighter for access.
The ticking on a cold start has now totally stopped - although I would have been really hacked off if it had continued.
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Re: O/S Exhaust fanimold gasket done ..........
« Reply #1 on: 15 October 2012, 15:03:39 »
Well done Rob  :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
amba
  • Medway towns
    • German V6
« Reply #2 on: 15 October 2012, 15:20:18 »
Pleased to hear its all done,Rob,and the result is as hoped for. :y
Mine was similar and had evidence of leakage on the original gasket,but unlike you I reconnected all the SAI as existing.I still get a bit of a noise on cold start but at 210k with some slightly noisey lifters I will now live with that.
Glad to have offered my experiences to you...like you I left the n/s well alone and got it done at a garage couple of years ago, as that scared me  :o
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 15 October 2012, 17:21:24 »
Got a feeling my offside one is goosed, I am sure the MOT man will tell me tomorrow  :'(
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #4 on: 15 October 2012, 18:30:41 »
Mine definately is, but as it was warm when it got to the ramp it was never picked up on.
I really should get it done soon though - it sounds proper ropey first thing, especially with the water pump squeaking away as it does!
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #5 on: 16 October 2012, 16:35:26 »
Failed on lambda reading, would this coincide with a leak ??
