Author Topic: Advice on fault codes  (Read 2532 times)
Craig32
  • Chesterfield, Derbyshire
    • 2.2 CDX Auto Petrol
« on: 15 October 2012, 21:55:41 »
Hi Everyone,
Advice needed! I have a Omega 2.2 petrol (auto) y 22 xe engine. I am getting the following fault codes using op comm:
P 0130 (4) O2 sensor open circuit present
P1555 TPS load signal not plausiblemy with engine load present
p0170 (2) Lean exhaust present
Further investigation revealed:
B1S1 Air/Fuel (Bank 1 Sensor1) Rich
B1S2 Air/Fuel (Bank 1 Sensor 2) Lean
She drives ok. The spanner light comes on about 2/3 miles into the journey. I am going to give it a full service at the weekend including plugs and clean out the breather pipes/throttle body. Any enlightenment as to the above fault code fix's would be much appreciated.
Cheers.
Re: Advice on fault codes
« Reply #1 on: 15 October 2012, 22:01:36 »
Look at the live values and post up the warm idle MAF figures  :y
Craig32
« Reply #2 on: 15 October 2012, 22:04:50 »
Will do on Thursday. :)
« Reply #3 on: 15 October 2012, 22:07:40 »
For info, P0170 is actualy a fuel trim malfunction  :y
« Reply #4 on: 15 October 2012, 22:08:18 »
For info, I expect you will find the Kg/h value to be less than 10 :y
Craig32
Re: Advice on fault codes Warm Idle MAF Readings
« Reply #5 on: 19 October 2012, 21:55:15 »
2.2 Petrol Auto
Ok, these are the warm idle MAF readings:
8 Kg/H
0.25-0.59
@ 2000 rpm
22 Kg/H
118-130
Interestingly the spanner light did not come on today but the emission light came on. "My Naff Code Reader"M said open circuit 02 sensor P0130.
Does this spread any light???
« Reply #6 on: 20 October 2012, 16:33:12 »
I would be inclined to replace the front sensor
Craig32
« Reply #7 on: 20 October 2012, 21:57:29 »
Which front sensor would that be?
  • Auckland
    • Mazda MPV
« Reply #8 on: 21 October 2012, 10:08:55 »
O2 sensor (Lambda sensor)
Craig32
« Reply #9 on: 21 October 2012, 21:51:37 »
Lamda sensor ordered. I suspect that's why she's such a pig to start from cold!
« Reply #10 on: 22 October 2012, 08:57:45 »
Hmmm, not sure on that. The lamda isn't used until it goes closed loop. Although who knows what routines the ECU runs when in an error routine  :-\
Craig32
« Reply #11 on: 22 October 2012, 13:34:56 »
I'm going to do the plugs and clean the throttle body out plus the emission/breather pipes this week and the change the 02 sensor. Will let you know what happens. Once she's got over the grizzles of starting from cold she's fine.
  • Auckland
    • Mazda MPV
« Reply #12 on: 22 October 2012, 19:58:30 »
Can you read the coolant temperature sensor with your code reader?
Craig32
« Reply #13 on: 22 October 2012, 21:46:13 »
I can read the temps with it.  :)
  • Auckland
    • Mazda MPV
« Reply #14 on: 22 October 2012, 22:02:53 »
Do the readings make sense?
ie with a stone cold engine does it read about 10 degC (or whatever the temperature was last night)?
Also worth checking the air intake temperature as well in case it is a factor in the cold start calculation.
