Pages: 1 [2] 3  All   Go Down
Author Topic: Shifnell headgasket change.....final checks  (Read 3856 times)
Tab
  • Telford
Re: Shifnell headgasket change.....final checks
« Reply #15 on: 25 April 2008, 16:11:11 »
If i can get my pas sorted i'll pop down just to be nosey and take some pics :y
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #16 on: 25 April 2008, 16:34:42 »
I'll be in Chester all weekend, otherwise I'd come to raise some spirits.
Growing old disgracefully...
« Reply #17 on: 25 April 2008, 17:33:21 »
I wont  ;D
maria
  • Derbyshire
  • I'm proud to be welsh :)
« Reply #18 on: 25 April 2008, 18:43:56 »
oh another message  >:(
Can someone bring a compression tester please  ;D
« Reply #19 on: 25 April 2008, 19:26:10 »
Its in.....this coffee had better be good  ;)
maria
  • Derbyshire
« Reply #20 on: 25 April 2008, 20:16:53 »
[/highlight]
It will be mark because i shall be making and chocolate cake to go with it  it ;)
« Last Edit: 25 April 2008, 20:18:11 by Maria »
« Reply #21 on: 25 April 2008, 21:05:44 »
[/highlight]
I love you...... :) :y
« Reply #22 on: 25 April 2008, 22:11:46 »
Jamie should have:
2 off headgaskets for a 3.0  CHECK
2 off exhaust manifold to head gaskets  CHECK
2 off exhaust manifold to front pipe gaskets  CHECK
4 off coolant bridge dowty washers  CHECK
4 off oil cooler to oil pipe metal washers  CHECK
1 off coolant transfer pipe to block rubber seal  CHECK
Oil  CHECK
Oil filter  CHECK - 7l
Anti freze  CHECK - 10l (plus 20l of water to get me there :o)
Sump plug washer - N/A - newer type with rubber seal
Water pump? (dont recall)  - CHECK
2 off stat housing to bridge pipe seals - CHECK
I also have an oil cooler on sale or return
And stat. You saif you had a new transfer pipe for stat if reqd?
« Reply #23 on: 25 April 2008, 22:12:35 »
Ok, just a quick post to see that we have everything required, I ahve got the following
1 pair of re-built 3.0 heads.
1 pair of exhaust manifolds
Full set of spare lifters
Spare bolts
Green Goo
Black Goo
Grey Goo
Flange sealent
Assorted O rings
Grease,
Copper slip
loctite thread lock
Full tool kit
Tap and die set
Torque wrenches
Misc spares
Cam cover gasket kit
Head bolts
I am not bringing my jack and stands (which we will need)   <<< packed
If we can get a list of tiems on here so I cna just check we have everything
« Reply #24 on: 25 April 2008, 22:13:31 »
Just being nosey, but who's having a head gasket change? :-?
The Boy......it would appear that he has a wetness problem.
It happens at my age....
« Reply #25 on: 25 April 2008, 22:15:04 »
Maria - I have an adjustable that goes to 32mm (as my viccy fan is 32mm), though its a bit wide if its tight.  I'll throw it in car anyway.
« Reply #26 on: 25 April 2008, 22:19:06 »
If anyone thinks of anything else, please send me a text msg.
Timbuk/Mark/Pete/Jimbob - send me the postcode by text msg, can't remember way (yes, navigation has made me lazy  :-[)
bertiecbx550
« Reply #27 on: 25 April 2008, 22:28:29 »
i was gonna go for brekkie in shifnal 2mora as i was on that run till someone cried at work and got put on the handsworth run instead... >:( >:(
« Reply #28 on: 25 April 2008, 22:33:59 »
Done  :y
Unit 20A
Lambsledge Lane Ind Est
Shifnal
TF11 8SD
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #29 on: 25 April 2008, 23:45:34 »
A message for you Mark.... if its not too much trouble and you have them, please can you bring a strobe light, a vac gauge and if you have one,  a 32mm viscous fan coupling spanner?  ::)
Is this spanner needed for the land rover Maria?
I will bring mine :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.031 seconds with 20 queries.
