Author Topic: Climate Control & Heating System  (Read 2163 times)
autobob
  • Malvern
    • 2002 2.2i CDX
« on: 24 October 2012, 16:59:45 »
Hi,
I noticed that I was losing coolant. Then the heater would not heat up - just blows cold - even when coolant level was topped up. I had the leak repaired - it was the top hose going in to the heater ( from engine compartment view). However, the mechanic could still not get the heater to work. He suggested it might be the Climate Control and I should get a specialist to look at it. The Climate Control really blows cold when set to 'LOW'. The fan slows to normal when the temperature selector is turned to, say, 26.
I don't mind paying for a specialist to look at it but does what the mechanic said sound right? I can't really afford to waste the money if not.
Would appreciate any advise.
Rob
Re: Climate Control & Heating System
« Reply #1 on: 24 October 2012, 17:11:34 »
It's possibly one of several things, but this might be worth a quick try ... at the back of the engine is the HBV - Heater Bypass Valve - looks like the starship enterprise , has 3 thick water pipes going to it, and a thin vaccum pipe to the top.
Disconnect the vac pipe and blank the end with a small bolt, leaving the HBV open to atmosphere. See if you now get hot air .. :)
If you do then you have choices .. leave as it is .. working nicely .. or track down the vac fault !!
« Reply #2 on: 24 October 2012, 17:15:38 »
Pic of the HBV
2woody
  • Northumberland
« Reply #3 on: 24 October 2012, 21:21:20 »
if your HBV is connected to vacuum from the engine, you will get no hot coolant to the heater matrix.
the HBV switches off the coolant supply to the heater, but only when both sides of the climate control are set to "lo" - in all other circumstances, the vacuum to the HBV is interrupted by the climate control. It's a very common mistake for the vacuum pipes to be connected wrongly and for you to have vacuum at the HBV permanently.
You can feel the coolant temperature entering the matrix - the pipes are behind the clutch pedal (or where it sused to be if you have the fun-free transmission). These pipes should be hot all of the time (apart from the LO-LO situation mentioned above)
autobob
  • Malvern
    • 2002 2.2i CDX
« Reply #4 on: 25 October 2012, 08:13:27 »
Thanks guys, really appreciate you sharing your knowledge. I will try your suggestions and let you know how I get on.
Cheers,
Bob
autobob
  • Malvern
    • 2002 2.2i CDX
« Reply #5 on: 25 October 2012, 11:55:31 »
I tried Entwood's idea of disconecting the vacuum tube as instructed but to no avail unfortunately. Thanks for the picture RobG - that was a great help in locating the HBV.
Any other suggestions please?. It all seemed to go wrong after I had noticed losing coolant - or is that just coincidence?
Anyway, I am grateful for your help and hope that someone can point me in the right direction.
Rob.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #6 on: 25 October 2012, 21:38:23 »
...and hope that someone can point me in the right direction.
Check you have two hot pipes at the matrix, as per the post by '2woody'...
  • Auckland
    • Mazda MPV
« Reply #7 on: 25 October 2012, 23:22:04 »
Rob.
Coincidences can happen....
The climate system uses the outside air temperature in it's calculations. Does your TID/MID/CID (computer display) give a plausible temperature reading?
« Reply #8 on: 25 October 2012, 23:55:28 »
The climate system uses the outside air temperature in it's calculations.  .....
It does on a facelift car, but not on autobob's 97 Elite  ;) ;) ;)
autobob
  • Malvern
    • 2002 2.2i CDX
« Reply #9 on: 02 November 2012, 18:55:25 »
Unfortunately, I have had to let her go :-[ Other things started to go wrong so thought I'd put the repair money towards another Omega. So I've been out and bought a beautiful 2.2i cdx (2002) with genuine low mileage and in lovely condition.
I hope my new baby will be as reliable and dependable as my old 1997 Elite. Goodbye old friend.
And thanks a million to you guys for all your help.
Regards,
Bob
