Author Topic: Rear Brake Pad Fitting Kit Dilemma  (Read 1817 times)
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
« on: 25 October 2012, 10:13:23 »
OK, I know I should ahve bought the GM pads which apparently come with the pins and springs but I didn't. Anyway, the supplier is having real problems getting the right parts.It's a '52 plate V6 Elite with vented disks and the pins and springs on all the listed kits, Bendix, Mintes and a-n-other i can't recall, have pisn almost 2 cm too short and the spring 1 cm too narrow. They are even speaking to the technical departments who are adamant that the parts/kit numbers are correct for the car - but they are far too short to bridge the caliper gap.
The old pins are ok(ish) but the springs have disintegrated. I know they are only anti rattle but I like to do a job properly. The GM pins are £5 each and the springs almost £7  :o so £35 is a bit steep.
Anyone had a similar problem?
Mrs Cakey
  • Suffolk
  • Cake, I need Cake, Give me cake!
Re: Rear Brake Pad Fitting Kit Dilemma
« Reply #1 on: 25 October 2012, 10:17:32 »
They're looking at the solid disk fitting kit ;)
Mrs Lazydocker to some. Thought it was about time I had my own name!
I have to keep posting things for him because he's still not got an account
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 25 October 2012, 10:22:40 »
+1  :y Been there also, once had to put back old pins and what was left of the springs because "no one" had the correct parts for vented rears available.
pauls
  • By the sea minehead
    • Bmw x3
« Reply #3 on: 25 October 2012, 10:28:22 »
pm andyc he will get you the right kit :y
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
« Reply #4 on: 25 October 2012, 10:33:32 »
That’s what I have told them.
Thanks.  :y  I’ll try to get the part number from him – I have paid for the kit already and returned it so easier for me for them to source if they have the number.
« Reply #5 on: 25 October 2012, 11:13:24 »
...... The GM pins are £5 each and the springs almost £7  :o so £35 is a bit steep.
The pins will likely be OK for the life of the car, so just replace the anti-rattle springs  ;)
