Pedders Suspension Bushes for the Omega
Started by Pedders Suspension, 01 November 2012, 12:46:04
One side at a time, and just follow the guide for removing the old bush. New ones push in :y
There is a guide zippy. Have a read. Any Q,s fire away.
Zippy2012
Quote from: chrisgixer on 13 March 2013, 10:08:27
Cheers chris i will have 2 find it & have a look through it... it looks like my LSD has finally died so i maybe replacing the diff if so i may just roll the whole lot out saves working on floor with my already knackered back!!
Quote from: Zippy2012 on 14 March 2013, 15:23:14
If replacing donuts, I do it all laid on my side. With a pillow. ;)
Pedders Suspension
It looks like you guys are busy fitting bushes  :)
We still have the set put aside for madflags.
If Chris or TheBoy could look up the details for madflags (or madflags1) and let me know what we should do with the one remaining set please?
Regards
Michael @ Pedders
Our mission is to give you straight advice, from specialists you understand and with No Bull!
Quote from: chrisgixer on 14 March 2013, 16:25:00
You really just go for a kip under there, don't you? ;D
Quote from: aaronjb on 20 March 2013, 15:03:16
It has happened, after battling then resting after fitting wishbone bolts, under a nice warm sump. Mmmm zzzzzzzzz. ;D
chrisr
Quote from: Pedders Suspension on 20 March 2013, 15:00:09
Regards
Michael @ Pedders
If there's one going spare I'd be interested.
Used the email function on here to contact madflags1.
See if he logs on. Last active Nov27th
bigtow
What's the lead time to get a set ?
2001 MV6 3.2 manual been converted from 2.6 auto
Pedders Suspension
bigtow
i would like to order a set whats the procedure now are we still doing it through oof or can i order direct from pedders and still get them for £80 plus p&p ?
Quote from: bigtow on 02 April 2013, 04:20:54
http://www.omegaowners.com/forum/index.php?topic=110208.0      :)
gstylebaby
Can i ask did we sort out the what was happening with the ones that had paid double postage. Also didn't you have something on the go with another bush carnt remember if it was fronts or rears......
Front wishbone vertical bush experiments are not going well unfortunately, if that's what you mean gt? Stability on the brakes being an issue. Although, a firmer bush giving more control does show promise. Under most other circumstances anyway.
If only we could find someone to make it for us. ::) ;D
Main problem cross referencing with other models seems to be, that no other manufacturer that has a poly rearward wishbone bush in production uses a 14mm diameter bolt hole. They all seem to be 12mm max.
So we're scuppered there too. :(
If we are to achieve a working rearward/vertical bush, it will need to have a very firm poly material thickness of around 4mm surrounding a ball joint taking a 14mm bolt hole, with outer body diameter at 49mm within a depth of a 26mm wishbone, most other poly ball joint bushes are much deeper. (Iirc).... this has to articulate within a subframe frame gap of 46mm without fouling.
I don't think a ball joint is achievable within those dimensions and have enough material on a vertical plain to stop the wishbone/poly popping over the ball joint, sadly. The forces involved are massive.
Someone needs to come up with a new design specific to the omega. (Because most other poly ball joints currently in production have a deeper subframe gap to operate in) and we already know at least one poly bush manufacturer feels the omega doesn't have enough numbers to justify tooling costs.
It's a big ask, unfortunately. :(
