Pedders Suspension Bushes for the Omega
Started by Pedders Suspension, 01 November 2012, 12:46:04
pauls
Quote from: Mr Gav on 28 April 2013, 20:23:39
Quote from: Shackeng on 28 April 2013, 10:05:12
and what a shame CG is no longer with us.  :'( :'( :'(
What happened to Chris? I think I missed something here   :o
Dont panic - Hes just having a long break....
Pedders Suspension
Quote from: zeicko on 13 June 2014, 17:36:07
will these help my omega with rear extreme inside tire wear ?
http://www.pedders.co.uk/pedders-rear-trailing-arm-offset-camber-rubber-outer-bush-pkt-2-kit-5803_p4500559.htm
They will certainly help, but it is still essential that your toe in settings are correct.
the bushes will take the rear camber back approx 3/4 degree.
Our mission is to give you straight advice, from specialists you understand and with No Bull!
zeicko
But will the fit a 1997 pre facelift caravan?
chrisgixer
Right. Had plenty of time with these for most people.
Any feed back? Good bad or in-differant.....? :)
YZ250
Quote from: chrisgixer on 19 September 2014, 18:15:37
Err yes, they have a good shelf life.  ;D ;D
chrisgixer
Quote from: YZ250 on 19 September 2014, 19:25:39
Ditto Kevin Woods here. ;D ...I think. Or did I give them to him recently... :-\
Love them 8)
Might not fit my second set to the Desmond, but then again... ::)
b4ndit
very good best thing fitted to the car :y
Quote from: b4ndit on 19 September 2014, 20:53:41
Say what you mean why don't you... I have to like them because it was my idea ;D
Mr Gav
So much better than the OE ones in every way  :y
I can confirm that they are absolutely useless after being subjected to 700-800C for about 40 mins. Sorry Hotel21  :-[
The 2 sets fitted to mine have kept my arse under control, though something has go awol on the Bullet to make it feel like the bush has failed.  However, bear in mind that I am comparing new poly to old, shagged GM ones...
chrisgixer
Quote from: TheBoy on 21 September 2014, 21:22:52
Aye? You have two sets of poly one on each car?
I notice a lot of noise from the back end of my car after fitting the donuts - but I think it's probably a wheel bearing on it's way out rather than anything coinciding with the bushes.. maybe made more noticeable by the change but not directly caused by, obviously.
Quote from: aaronjb on 22 September 2014, 10:57:50
Oh, joy! ::)
