Author Topic: Ignition lock problem  (Read 2043 times)
« on: 02 November 2012, 19:05:49 »
Got in the Omega today put the key in ignition but it wouldnt turn no matter how much wiggling,pushing or pulling etc. I gave it.
Wiggled the steering wheel which put the steering lock on which made things worse if anything.
Tried the spare key,but that was just the same. Time to change the lock/barrel ? :-\
Re: Ignition lock problem
« Reply #1 on: 02 November 2012, 19:07:49 »
« Reply #2 on: 02 November 2012, 19:22:46 »
Brilliant as usual Rob.Thanks. :y
I think its time someone made you an admin. ;) :)
« Reply #3 on: 02 November 2012, 19:25:01 »
Don`t you bloody start, you know what happens when comments like that are made ::) :-X
« Reply #4 on: 02 November 2012, 19:27:13 »
Umm, tbh, no. ???
But I honestly think you would be perfect for it if a vacancy was there. :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #5 on: 02 November 2012, 20:02:26 »
I think a vacancy should be created...
« Reply #6 on: 02 November 2012, 23:25:40 »
Seconded...... :y :y
We had this problem some years ago with a 95 select, called the AA who forced it with the help of Mole Grips, never a further problem, though swmbo carried the Mole Grips in the car for some time.... :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #7 on: 03 November 2012, 21:03:12 »
Same problem here so I gave it a good squart of white greese.
Not a fix but it helps  :y
« Reply #8 on: 03 November 2012, 21:06:47 »
Funny you should say that.I squirted a bit off WD 40 in there earlier today and its working as smooth as silk now,so replacement will move further down the to do list now. :)
« Reply #9 on: 03 November 2012, 21:08:27 »
Must be a couple years worth on it by now :D ;D
« Reply #10 on: 03 November 2012, 21:12:29 »
At least. :y ;D
I keep getting more upgrade bits (latest being ccr 2006 plus Bose gubbins,with rear shelf & blind) so the list never seems to get shorter. Need to change the stat first though. ::)
« Reply #11 on: 03 November 2012, 21:32:17 »
And then theres the rear bumper with parking sensors and associated bits & pieces.......
Remove and reinstall the front end of LPG etc. etc. etc. ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #12 on: 03 November 2012, 22:23:58 »
Flood it with WD40, if that works then the next step is to get rid of the stuff before the oil gets to work on the contacts, sounfs like crap in there, assuming the right key.
« Reply #13 on: 03 November 2012, 22:26:09 »
Will spray some contact cleaner in there tomorrow to clean it out.Thanks Chris. :y
« Reply #14 on: 04 November 2012, 10:41:24 »
I had this problem once. Worth following the refurb procedure before it lets you down completely and you can't get the barrel out.
http://www.omegaowners.com/forum/index.php?topic=90600.0
In my case, it was jamming because the part labelled "sprung pin"was sticking because the track it runs in in the barrel was burred. Gave it a polish up with a dremel and a good lube in addition to the other steps in the refurb and it's good as new now.
