Author Topic: sorry people another heater problem  (Read 1825 times)
willow tree
  • Oxfordshire
  • One very badly behaved car [Nickname Mr Friday]
    • Omega 3.2 V6 24V Elite
« on: 04 November 2012, 17:38:21 »
i have a 2001 3.2 V6 Elite,and the heater does not work,i checked both [top hose in and bottom hose out] i engine bay to the heater matrix and both are hot,the temp of car is at normal operating temp but no heat. but if i drive for about 30 minutes i start to get very luke warm air through the vents but also i can select full fan speed or low fan speed and the air flow is the same even though the fan works from low speed to high speed,any ideas,i fed up with ice on the inside when i arrive at work oh yes i forgot when fan is working the inside mists up so then i have to open the window which adds to the problem
kind regards willowtree
gsizoli
  • Hungary
Re: sorry people another heater problem
« Reply #1 on: 04 November 2012, 20:34:39 »
Perhaps your heater matrx is full with scale.. :-\
It's worth to check the electric motor below the expansion tank...
« Reply #2 on: 04 November 2012, 20:37:51 »
Try resetting the climate panel first :)
