Author Topic: help please soaked door  (Read 1281 times)
darrenfos
  • eastleigh
    • omega elite manual
« on: 04 November 2012, 18:41:31 »
hi all does the membrane on the doors act as a water barrier from rain water as the door card is soaked at the bottom drivers door. with panel off sat in car and got someone to hose it, the water was coming from the black panel where the blue sensor is can someone help please.
omega is like marmite you know the rest
Re: help please soaked door
« Reply #1 on: 04 November 2012, 19:05:20 »
Drain holes clear :-\
darrenfos
  • eastleigh
« Reply #2 on: 04 November 2012, 19:09:19 »
yep the holes are clear but the membrane is not on as it should be so i have made a new membrane with no splits or tear's just got to find something to stick it with that should stop it from coming in the car, i hope what do you think cheers Darren.
« Reply #3 on: 04 November 2012, 19:10:33 »
Clear low modulus silicone
darrenfos
  • eastleigh
« Reply #4 on: 04 November 2012, 19:13:12 »
do u think the dodgy membrane is where the leak is coming from
« Reply #5 on: 04 November 2012, 19:15:35 »
Quite possible. Replace & seal ensuring drain holes are totally clear then apply the "hose test" again.
