Author Topic: fault codes  (Read 1294 times)
douglas6163
  • exeter ,devon
    • 2001,2.6 omega cdx
fault codes
« on: 06 November 2012, 10:19:03 »
Hello to everyone i am a new member and in desperate need of help.I have done a pdal test and have the following codes 1700,0500,0300,0301,0302,0303,0100.I do know what they mean but would like to know which one or if all are the actual fault.Money very tight at mo and dont want to be replacing parts i dont need to. I drive a 2001 2.6 cdx, please help i am very desperate. Car misfires from cold but when warm will lose power and stall when stationary.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: fault codes
« Reply #1 on: 06 November 2012, 10:28:12 »
douglas6163
  • exeter ,devon
Re: fault codes
« Reply #2 on: 06 November 2012, 10:50:56 »
Thanks for that but really wanted to know if just one fault caused all the others or if multiple faults .done the0100 mass air flow sensor last year so probably not the cause.I dont want to be spending £200 on atf change if all that is needed is speed sensor.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: fault codes
« Reply #3 on: 06 November 2012, 10:56:30 »
Somebody will be along later who knows more about DBW engines  ;)
Have you had any work done on it reciently ?
Re: fault codes
« Reply #4 on: 06 November 2012, 11:04:54 »
Not sure of the others, but the 03** numbers are all misfires fires from the same (driver's?) coil pack. So that would be a good place to start looking.  :y
douglas6163
  • exeter ,devon
Re: fault codes
« Reply #5 on: 06 November 2012, 11:14:41 »
no work done recently just started playing up on saturday.
Re: fault codes
« Reply #6 on: 06 November 2012, 17:20:24 »
Wouldn`t that be 0301, 0303, 0305, ???
Re: fault codes
« Reply #7 on: 06 November 2012, 17:42:07 »
As usual Rob, you've a point!  ::)
Re: fault codes
« Reply #8 on: 06 November 2012, 18:47:09 »
from memory
1700 = gearbox
030x = misfires
0100 = maf
Thus, I'd like to see live data from MAF
If that is not available, try it for a couple of days with MAF disconnected, and report back
douglas6163
  • exeter ,devon
Re: fault codes
« Reply #9 on: 13 November 2012, 09:24:13 »
thanks for all the help and advice everyone turns out it was maf sensor after all.
