100w full beam bulbs
Started by bigtow, 06 November 2012, 21:25:34
bigtow
I want to upgrade the full beam bulbs and was looking at some 100w ring bulbs it says not for road use so I have two questions one will the omega wiring take the load of a pair of 100w bulbs and two can you get done for fitting them . In my younger days I used to have 80/100w bulbs in my escort but I wasn't worried about getting nicked back then ?
2001 MV6 3.2 manual been converted from 2.6 auto
I had the same bulbs fitted to my Manta  ;)
Not sure if the wiring would support the extra current required by the 100w bulbs, & I'd be wary of the extra heat behind a plastic lens  :-\ :-\
#2
Quotewill the omega wiring take the load of a pair of 100w bulbs
Probably
Quotecan you get done for fitting them
Yep
QuoteYep
but who's going to check?  ::)
Quote from: Andy B on 06 November 2012, 23:18:34
QuoteYep
Judging by some aftermarket "improved" lights I see, the Police. IF they're doing their job. ::)
You are playing into their hands if they decide they are going to pull you over and find something. Given that the standard main beams are excellent I can't see the point of risking a pull or overloaded wiring, TBH.
Quote from: Kevin Wood on 06 November 2012, 23:24:25
QuoteYep
Given that you'll only have your main beam on when there's no other traffic ........  ;) Police aren't going to see them.  ;) ;) ;)
QuoteYep
You not driven an non HID Omega then ::) ::) Standard lights a crap......... :y
flyer 0712
May be try the upgraded bulbs..same wattage but better light out put...put them on my miggy and they are a great improvement to the dull standard ones...
henryd
Quote from: yar244 on 07 November 2012, 01:03:42
+1 I put osram night breakers in my Disco's headlights and the difference is very noticeable :y
other rides
Olympia5776
Quote from: henryd on 07 November 2012, 09:13:49
I've just fitted them to our Freelander and Transit and yep, they make a noticable improvement
Quote from: Vamps on 07 November 2012, 00:08:06
QuoteYep
worse than crap.. :-\
as aftermarket xenons become illegal for mot last year - I discovered why, because number plate reading cameras cant read through them at night ;D  and they cant calculate my avg speed at nights ;D ;D ;D -  every 2 years for mot I convert them to normal and then xenons back again.. :-\
Varche
Quote from: cem on 07 November 2012, 12:27:57
QuoteYep
Gosh........ Every 12 months here or six months for vans.
Quote from: Varche on 07 November 2012, 14:22:35
QuoteYep
opps.. I have 2 cars and already complaining about it ;D
Keith ABS
  You could try fitting 50% brighter lamps from a reputable maker. Used these years ago in my old Senny and then the Carlton. Fantastic differance. Another way of running the 100watt is to wire through a seperate relay for the power. Did this on a Mk1 Cav with Manta quad headlamp conversion on it.
Keith B
