Author Topic: x30xe cams  (Read 2354 times)
Andy89
  • Norway
    • 97 3.0 MV6
x30xe cams
« on: 07 November 2012, 22:00:06 »
I have got 2 set of cams, and then i heard something about there is a gain by putting intake cams on the exhaust side aswell, is that true?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: x30xe cams
« Reply #1 on: 07 November 2012, 22:39:51 »
i thought it was the otherway around, but getting on a bit since I heard that.
Re: x30xe cams
« Reply #2 on: 07 November 2012, 22:44:04 »
I thought the consensus was G's on inlet, A's on exhaust, as it comes out of the factory
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: x30xe cams
« Reply #3 on: 07 November 2012, 22:49:04 »
I put the stock 3.0 cams in correct order in my old 2.5 and it did wake the old girl up a bit,wouldn't have thought putting exhaust cams to inlet would make much difference to a 3.0 though ???
other rides
Andy89
  • Norway
    • 97 3.0 MV6
Re: x30xe cams
« Reply #4 on: 08 November 2012, 07:14:41 »
I'm not expecting a big difference, but all helps if this is a gain.
I cannot afford changing the lift on the cams, so i'm looking for a cheap solution for some extra hp
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: x30xe cams
« Reply #5 on: 08 November 2012, 13:10:27 »
It should help it breath a little easier if you drop them in then change the exhaust manifolds for the 2.6 / 3.2 ones as they are known to flow better.
Would be interesting if you could get a before and after dyno reading  ;)
Andy89
  • Norway
    • 97 3.0 MV6
Re: x30xe cams
« Reply #6 on: 08 November 2012, 13:17:23 »
Headers are allready fitted :D
Re: x30xe cams
« Reply #7 on: 08 November 2012, 14:40:22 »
Fitting the inlet cams on the exhaust side wont make any great gain.
Increasing lift wont have a big impact either as that only inceases the curtain area and the standard lft already matches port size.
Its playing with duration and ramp rate which might give gains,
symes
  • oxford
    • R reg 940 volvo
Re: x30xe cams
« Reply #8 on: 08 November 2012, 21:15:46 »
went to scrappy earlier yhis year and got cams from ex plod 3litre and they were G cams all round and when i went to put them in my 2.5 elite--same cams ???
Re: x30xe cams
« Reply #9 on: 09 November 2012, 20:49:49 »
I suspect you were reading the wrong code as there is also one for the stock (un ground) cams which is the same on all of them
