Author Topic: Wheel Size & Handling  (Read 3386 times)
Rog
« on: 08 November 2012, 10:24:22 »
I recently changed from a 2002 2.6 V6 CDX Est (Blue one) to a 2000 2.5 V6 Elite Est (Silver one). Why ? Well its a long story but involved a serious oil leak.
I much prefered the handling of the CDX, the Elite seems heavy and a bit more hard work.
The Elite has bigger wheels. Are these original spec ? Is there any advantage other then the "Bling" factor ? Are there any disadvantages ?
I'm gonna need tyres fairly soon so I'm wondering whether to try to get an old set of smaller wheels. I carry quite heavy loads in the back sometimes.
Before you ask, the old car got scrapped before I even thought about wheel swapping  :-\
Old
"New"
Re: Wheel Size & Handling
« Reply #1 on: 08 November 2012, 12:31:44 »
Some find the Elite self-levellling suspension setup a bit wallowy.
The larger tyres can lead to a bit more tramlining but I very much doubt it would make that much of a difference. Standard size of rubber on the Elite is 235/45/17.
Tyre brands will make a significant difference, as will geometry setup. Might be worth getting it set up competently first, as it's a "new to you" car?
You say if feels heavy.. In the steering or just generally? I've noticed a fair variance in the level of steering assistance having driven a few Omegas, and this can be adjusted using a Tech 2, although I personally prefer the minimum level of assistance as this seems to provide more "feel" through the steering.
Rog
« Reply #2 on: 08 November 2012, 17:52:58 »
Well both, steering seems to need more effort, and the car generally, but I understand the latter as it is a heavier car due to leather seats, more kit etc.
I didn't know that it had self-levelling suspension. So that should make it better for carrrying heavy loads then ?
By "geometry" I assume that this means tracking etc ?
But overall, the response does not really point a finger at the bigger wheels etc. So stick with them then.
Thanks
« Reply #3 on: 08 November 2012, 19:22:40 »
If it still has the self levelling (check it ;)), it can feel really soft.
The steering should feel the same.
Geometry is so much more than tracking, see www.wheels-inmotion.co.uk
Rog
« Reply #4 on: 08 November 2012, 21:02:47 »
£%$^&**^%%  . . . . I almost drove right past this place today
« Reply #5 on: 08 November 2012, 21:03:37 »
You'd need to book anyway.
« Reply #6 on: 08 November 2012, 21:20:12 »
If setting up, check for faults first and rectify. THEN set up.
Bushes track rods and ball joints. Broken springs and failed leaking shocks etc etc
Having seen what regulates the steering assistance, I'm amazed we get two alike when it comes to steering feel/pas
« Reply #7 on: 08 November 2012, 21:23:53 »
And suspension on the Elite is very much softer and ponderous compared to the rest of the range.
« Reply #8 on: 09 November 2012, 13:07:10 »
Also worth noting that the 17" wheels actually have a smaller rolling radius than the 16"s :y
Rog
« Reply #9 on: 09 November 2012, 14:55:39 »
Right. I had to Google what that means. So the wheel has to turn more times to achive the same movement, so possibly use more fuel and decrease overal performance ?
« Reply #10 on: 09 November 2012, 15:03:47 »
The difference actually equates to about 1.3" or -1.6% :y You might only get 100 miles from a given amount of fuel rather than 103 ::)
Really not worth fretting over :y
« Reply #11 on: 09 November 2012, 15:15:05 »
The rolling resistance of a given tyre will have far more impact than the difference anyway :y
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #12 on: 09 November 2012, 15:43:41 »
Nowt to do with wheels but just a thought, are your rear seats heated, and do you have rear parking sensors?  ???
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Bixy1
    • Cats Tails
« Reply #13 on: 09 November 2012, 15:46:46 »
Another thought, mine had the 17's on when I bought my Elite but the tyres were bald, but I dropped lucky at the scrappies and got a set of the earlier 16's. The car seems to ride slightly higher.  :-\
« Reply #14 on: 09 November 2012, 16:45:43 »
That because the overall diameter of the wheels is (marginally)greater, together with the fact that the sidewall of the 16" tyres is a touch deeper :-\ More of a visual illusion though :y
