Vauxhall Customer Aftersales Assistance Centre
Started by Auto Addict, 08 November 2012, 15:17:57
To improve airflow over the radiator :y same as pfl Omega grills :y
Quote from: Entwood on 08 November 2012, 21:39:02
Excuse me for being thick ... but the towbar goes on the BACK .. so why does the GRILL need modification ???
Quote from: ex taxi al on 08 November 2012, 21:41:32
What he says ^^^^ ;)
So they've built a car, and got type rating for a tow bar, and PUBLISH it can tow up to 1800 kgs ... but it's going to overheat if you do any of that .....
you couldn't make it up really .... :(
Increased load, decreased air flow due to less speed = less cooling. Hence more free flowing grill needed.
...as vx have been tight wads on r+d again.
Would expect nothing less from a rebadged Buick tbh ::)
Quote from: chrisgixer on 08 November 2012, 21:47:06
Quite the opposite when you think about it as they are trying to minimise drag and have designed in the ability to mod the grill when a pikey hook is fitted so as to increase cooling
MFL TD Elites are supposed to have grill changed for towing
They modified the Omega's superior predecessor during its lifetime to give a greater air flow through the egg box grille (they cut the blanking plate behind it in half  ;))
Auto Addict
I like red cars
Quote from: Marks DTM Calib on 08 November 2012, 22:11:17
I just KNEW you'd say that. ;D
But should it need the mod at all...? Surly the total cooling capacity should be able to cope with not toeing AND toeing without messing about with the grill ?
Auto Addict
Quote from: chrisgixer on 09 November 2012, 08:53:59
Oi! What do you know about towing? :P
;D ;D ;D ;D
I like red cars
Quote from: Auto Addict on 09 November 2012, 09:14:50
;D ;D ;D ;D
Living as close as I do to tunnie, I'm always towing him ;D
Quote from: TheBoy on 09 November 2012, 13:11:43
;D ;D ;D ;D
Hmmm.... Yes.... Here we go again ::) ::)
So you propose compromising the drag factor for the corner case of users e.g. those with a pikey hook  ???
Total cooling capacity is clearly able to cope or it would over heat with the mod
