Author Topic: What does this mean???  (Read 2575 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 08 November 2012, 21:59:50 »
I have a new message on my MID....
Low Beam
Fld/Vision
Any ideas what it is? I did have something going on with my auto headlight levelling but I think that has gone away???
Re: What does this mean???
« Reply #1 on: 08 November 2012, 22:02:37 »
Yup, headlight levelling.
Usually either the sensor has popped its arm off, or a servo motor has seized - is one light low, or both low?
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #2 on: 08 November 2012, 22:05:54 »
Had same problem.....was the sensor as TB says. It was the one just in front of the nearside real wheel in my case. Simple repair....either arm needs popping on or replacement sensor. Again, easy to replace :y
HockeyDave55
  • Milton Keynes
« Reply #3 on: 08 November 2012, 22:07:16 »
I don't think either one is???
I will find a wall and have a look tomorrow, also have a look at the arms in the daylight...
Thanks for the pointer...
Is there any way to test???
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 08 November 2012, 22:18:29 »
I had a gremlin in system some years ago - headlight field/vision or something came up irregularly over say a 3 year period -nothing found so I ignored it and has not recurred in almost 3 years now. Just see how it goes before spending time and money on it - cannot remember if any coes showed. Kevin ran Tech II on it early 2010 - no codes I recall.
« Reply #5 on: 08 November 2012, 22:20:39 »
A proper code reader will tell you which sensor & presumably which headlamp motor is faulty
« Reply #6 on: 08 November 2012, 22:22:20 »
If it's the sensors, then it should be blindingly obvious what the problem is when you look :y
HockeyDave55
  • Milton Keynes
« Reply #7 on: 08 November 2012, 22:29:29 »
I'm guessing if the arm has fallen off???
« Reply #8 on: 08 November 2012, 22:36:33 »
Aye :y
HockeyDave55
  • Milton Keynes
« Reply #9 on: 08 November 2012, 22:37:50 »
Aye :y
Thank you, I will have a look at work tomorrow.... :y
« Reply #10 on: 08 November 2012, 22:39:36 »
Not always  :-\. Mine was goosed electrically but looked perfectly OK.  :y Tech II said it was the front sensor & A N Other sensor fixed it.
HockeyDave55
  • Milton Keynes
« Reply #11 on: 08 November 2012, 22:42:19 »
I have a LAUNCH box at work, if I have time, I will plug it in... Thanks for the pointer. :y
