Author Topic: Rear Wheel Bearing  (Read 2493 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Rear Wheel Bearing
« on: 10 November 2012, 22:18:26 »
 I am just changing the rear wheel bearing, i have got the hub out but i cant get the old bearing out of the Hub, is there anyway of doing it without a proper tool. If not has anyone local to be got one i could borrow.
Re: Rear Wheel Bearing
« Reply #1 on: 10 November 2012, 22:25:24 »
I watched a young gentleman in Trowbridge remove mine for me .. took him less than 30 seconds after attaching his home made bearing puller ........  a sight to behold that involved a few welded pieces of fairly heavy steel, some nuts and bolts, an axle stand ...and the final piece ... a large sledgehammer .....    a few moments aligning it all, then 3 blows with the sledge and out it popped !!!
Epic !!!  :y :y :y :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 10 November 2012, 22:45:41 »
 a big long sharp chesil and a big hammer... just batter it till it comes out...make sure the car is well supported on stands.
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 10 November 2012, 23:26:10 »
If you're near the Medway Towns, I have the tools you need to finish the job.
The hard part is removing the hub!
Let me know,
Nick
biggriffin
« Reply #4 on: 10 November 2012, 23:38:34 »
 dont know if i've miss read it but i think he has the bearing out off the wishbone ,but the race is stuck on the hub,if so just cut the race off the hub with a small cutting disc on an,angle grinder.
Hoof'land storeman.
spanish_lad
  • spain
    • 1995 25XE saloon
« Reply #5 on: 11 November 2012, 02:23:13 »
pick up a set of bearing pullers for 20 quid or so. makes the job so much easier.
if i hear "its dealer only" one more time im gonna set fire to the mig :p
downsmen
  • Kent
« Reply #6 on: 11 November 2012, 09:33:00 »
Thanks for your advice, Nick i have sent you a PM
Thanks again
Paul
downsmen
  • Kent
« Reply #7 on: 11 November 2012, 19:43:53 »
Hi Nick
Thanks for lending me the bearing puller, it makes life really easy. the hardest part was putting the hub back in.
I will bring the puller back sometime in the week. :y
Many Thanks
Paul
