Author Topic: headlight - taillight check- update  (Read 1639 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 11 November 2012, 16:36:26 »
re. headlight / taillight ckeck. i have followed all advice from replies i got from previous post . all lights are ok, but i still have the error message whenever i use my lights. will i need a tech 2 to wipe the message. :-\
Re: headlight - taillight check- update
« Reply #1 on: 11 November 2012, 16:39:40 »
In the past others have commented how poor quality light bulbs (non-Bosch) can show a fault reading even though they are working perfectly ok.
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 11 November 2012, 16:57:02 »
no bulbs needed to be changed & ive never had this message before. irony of it my mig passed its mot only a few hours before the check message appeared. which has made me wonder if when they checked the towbar electrics , could thier equipment have caused it.
« Reply #3 on: 11 November 2012, 17:03:43 »
The fault being there means the system is reading a bulb failure .. a techII session will make no difference at all.
Solution is simple, find out which bulb the system "thinks" has failed. Buy a decent quality bulb and replace each bulb in turn, or, more simply, buy 4 decent bulbs and replace them all .. :)
« Reply #4 on: 11 November 2012, 17:06:02 »
Check system does not cover towbar, double check all bulbs are working  :y
« Reply #5 on: 11 November 2012, 17:06:40 »
That is possible.
Once my MOT inspection led to the headlight level system device on the front nearside wishbone being damaged! :(   So yes the MOT inspector could have done something to create the fault.  I would certainly inspect the towbar electrics.
« Reply #6 on: 11 November 2012, 17:11:57 »
+1 and/or replace all bulbs with good quality ones (Vx genuine or Ring work well with Omegas) - Halfords bulbs do not!  ;)
Taxi_Driver
« Reply #7 on: 11 November 2012, 17:33:39 »
I'm sure you have checked the number plate lights  :)
« Reply #8 on: 11 November 2012, 17:57:49 »
Number plate lamp isn't on the check system  ;)
