Author Topic: Cambelt Roller Came off while driving. Should i worry??  (Read 5179 times)
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« on: 11 November 2012, 18:39:06 »
One of the roller for the cambelt completely disintergrates while driving the car at around 20 miles per hour. I tried starting the car and it would not start so had the car towed. Question is, is it possible in such a scenario not to damage the engine???  The belt did not snapped just came loose. If damage occured what am i looking to replace. I am dreading the thought of having to get another engine from UK as i live donkey miles away. Please help!
symes
  • oxford
    • R reg 940 volvo
Re: Cambelt Roller Came off while driving. Should i worry??
« Reply #1 on: 11 November 2012, 18:42:17 »
would think you bent valves there mate when you turned engine over trying to start it :'(
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #2 on: 11 November 2012, 18:49:40 »
Please bear with me but are valve a straight replacement? I mean no skimming or anything of that sort. Luckily for me labour is super cheap here.
« Reply #3 on: 11 November 2012, 18:51:02 »
If you are very lucky. You'd need to check the valve guide too for damage.  :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 11 November 2012, 18:52:00 »
+1 :y
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #5 on: 15 November 2012, 05:18:28 »
I was extremely lucky as my engine was not damaged at all. I fitted a new gates belt and rollers and all seems well, however i have noticed the car rev counter is not exceeding about 4500 rpm. Any ideas?
« Reply #6 on: 15 November 2012, 06:22:41 »
Camshaft sensor
  • Auckland
    • Mazda MPV
« Reply #7 on: 15 November 2012, 21:36:53 »
Camshaft sensor
Probably. But could be any one of those codes that causes the ECU to apply a 4500rpm rev limit.
You need to get an OBD2 code reader on it to read the codes and find the cause.
« Reply #8 on: 15 November 2012, 21:41:12 »
TBH, I'm amazed that it runs at all if the cambelt idler disintegrated :-\ :-\
Unless it's an 8 Valve engine :-\ :-\ ???
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 15 November 2012, 21:50:58 »
does it sound ok???
RIP Paul Lovejoy
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #10 on: 16 November 2012, 04:15:22 »
Car runs very rough and incase you turn on the AC the car goes off. I did spot alot of oil in the plugs well and i suspect that is why it is running rough.. I had a spare brand new camshaft sensor and had it fitted and now once the car warms up the the rev counter is going all the way up!! Engine has full power as always but does cut out every now and then. But i have a persistent message that keeps coming up:
P1405  Present
( 8 )  Feedbacksensor Exhaust Gas Recirculation
What is it?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 17 November 2012, 15:53:42 »
P1405  Present
What is it?
I checked autodata and that code is an EGR fault,maybe worth removing the EGR valve and giving it a clean :y
other rides
« Reply #12 on: 17 November 2012, 16:04:29 »
P1405  Present
What is it?
Usually oil in the plug wells means failed cam cover gaskets.  However with your initial problem, that usually causes top end engine damage, I would fear a damaged head and valves.  :'( :'(
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #13 on: 17 November 2012, 17:32:34 »
P1405  Present
What is it?
Thanks mate was thinking of the same but as a precaution i want to buy another just in case...
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #14 on: 17 November 2012, 17:35:45 »
P1405  Present
What is it?
Actually the cam cover gaskets have failed and we replaced them as well. I am finding it hard to believe but the engine was not damaged at all..the car runs very smooth and the rev counter goes all the way to max...I replaced the camshaft sensor and all is running so well now
