Author Topic: best thing?  (Read 4619 times)
Re: best thing?
« Reply #15 on: 12 November 2012, 13:51:41 »
I was happy to change the engine not only because of what i was told but because i love the car and having 147k on the clock it would keep me going for many more years
If serviced properly (which excludes main dealers) it will do another 100k no problem at all.
Symptoms man. Symptoms...?
Coolant loss? Miss fires? Rough running? Poor starting? ... And even if you have all of those there's numerous possible causes that don't involve hg.
Re: best thing?
« Reply #16 on: 12 November 2012, 14:38:47 »
Best thing is not to go back to that garage  :y
grannon_mv6
  • Hull
    • 2002 2.6 mv6
Re: best thing?
« Reply #17 on: 13 November 2012, 00:31:11 »
I've had nothing at all. I'm going to start to go where we get our work cars done plus I get 10% off
Drive it like you stole it
jonathanh
  • coventry
Re: best thing?
« Reply #18 on: 13 November 2012, 12:22:07 »
 i would personally start by doing nothing
the experience here is that HGs on the V6 very rarely fail.  however it is common to get mayo in the filler neck, particularly in cold weather on short journeys.  it is nothing to worry about certianly nothing to spend money on.
best approach is to continue to use the car, watch for anything going wrong but chances are there is nothing wrong at all.  also the v6 is capable of getting well past 150k miles if looked after so don't worry
pete220
  • chipping norton
    • Omega MV6 3.0
Re: best thing?
« Reply #19 on: 13 November 2012, 12:54:11 »
Maybe buy the engine if its that cheep and keep it if you love the car that much then if anything goes wrong you have a spear  :y
grannon_mv6
  • Hull
    • 2002 2.6 mv6
Re: best thing?
« Reply #20 on: 13 November 2012, 21:25:31 »
i think i do 14 miles to work and back 3 times a week and very little more, but if i work at our other base i will do 120 miles a shift. How doea the neck come out? Does it just unscrew?
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: best thing?
« Reply #21 on: 13 November 2012, 21:40:00 »
You have to bend up a plastic tab that locks the neck to a bolt at its base. Then just twist it a quarter turn. But the mayo is nothing to worry about. Its just condensation at the top of the filler neck because its cooler up there. Very common at least here in norway because of the cold weather.
grannon_mv6
  • Hull
    • 2002 2.6 mv6
Re: best thing?
« Reply #22 on: 14 November 2012, 11:22:39 »
ive checked my dip stick and got nothing so all is good. Once i remove the neck will my cap just fit in its place or do i need a new one?
Re: best thing?
« Reply #23 on: 14 November 2012, 11:37:59 »
Cap fits.
grannon_mv6
  • Hull
    • 2002 2.6 mv6
Re: best thing?
« Reply #24 on: 14 November 2012, 14:49:00 »
cheers for help everyone
Tony H
  • liverpool
  • Black Elites are luurvley
Re: best thing?
« Reply #25 on: 14 November 2012, 18:30:00 »
I bet the garage hasn't done a compression test or checked for exhaust gasses in the expansion tank  ???
Re: best thing?
« Reply #26 on: 14 November 2012, 18:53:37 »
Some oils are more prone to producing mayo up in the neck. Castrol sucks up moisture like blotting paper.
symes
  • oxford
    • R reg 940 volvo
Re: best thing?
« Reply #27 on: 14 November 2012, 20:48:07 »
Mine done nearly 240000 miles mayo on cap is nothing to worry about if every mig v6 owner went and changed engines because of that there woulnt be anough to go round :y :y
