Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: Bad running (Electrical or Mechanical)  (Read 8468 times)
Re: Bad running (Electrical or Mechanical)
« Reply #60 on: 21 December 2012, 15:36:45 »
I am making a flying visit to Oxford this evening, if you're in Symes, I can lob the Tech2 in the boot for a quick plug-in and check
symes
  • oxford
    • R reg 940 volvo
« Reply #61 on: 22 December 2012, 20:15:02 »
Sorry mate it was my lads Birthday yesterday -BUT got code p0700 - have no Snow switch/Sports mode
Oil level ok so removing selector switch and cleaning-Then that should do it-Do you agree???
« Reply #62 on: 22 December 2012, 20:57:38 »
Need to read gearbox ecu, if you have the capabilities to do so :y
« Reply #63 on: 22 December 2012, 20:58:04 »
If you dont, its a good start, though :)
symes
  • oxford
    • R reg 940 volvo
« Reply #64 on: 22 December 2012, 21:01:19 »
Will do as said mate- will be done over xmas holiday- if problem there afterwards will pm you ok :y :y
« Reply #65 on: 22 December 2012, 21:02:38 »
symes
  • oxford
    • R reg 940 volvo
« Reply #66 on: 23 December 2012, 17:32:34 »
Done  :y :y :y :y :y :y :y
spray electrical cleaner on all switchs and earth points on base of gearshift under leather gaiter :y :y :y :y :y
So simple yet everyone thinks inside the (gear)box :y :y :y
got mate popping over later to plug in and check :y
But miggy does as it should=shifts thru gears no problem and sports/snow buttons/modes work :y :y
Am sure Boggy will be happy now :y :y
« Reply #67 on: 23 December 2012, 18:11:54 »
Good news :y
If Range switch issues reoccur, might be worth replacing switch (with 2nd hand), as cleaning does not always work.
Boggy
« Reply #68 on: 23 December 2012, 18:23:29 »
 :y Happy indeed but seeing is believing, Although I do believe ya! May have to go buy some Gnomes now  :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #69 on: 23 December 2012, 18:34:20 »
or get some old motorbike parts and I make you a sculpture-dont ask mate long story ;)
« Reply #70 on: 23 December 2012, 20:23:16 »
Good news :y
But range switch isn't under the leather gaitor. :-\ Can't think of much under there that would affect operation of the gearbox, the only switch is for key removal inhibit. Unless something was shorting the wiring to the winter / sport mode switches or the LED display? I can see that giving the autobox ECU the hump. Either way, not sure I'd expect a spray of cleaner to have effected a permanent cure. :-\ See how it goes, I guess.
symes
  • oxford
    • R reg 940 volvo
« Reply #71 on: 23 December 2012, 20:29:18 »
been out-took it to see my dad -No probs at all. Shake your head in disbelief BUT it did something!!  cos it runs normal :y :y
Even tried sports mode and snow start modes=fine :y :y :y
Boggy
« Reply #72 on: 23 December 2012, 22:40:45 »
Could be a case of moisture in the wiring, leccy spray would possibly cure that? the car had been sat a while so could have added to the problems I already had, leave no stone unturned but the main issues have been rectified, simple problems which shouldn't have been there in the firt place so symes idea to go back to the beginning certainly paid off. Still, we shall see.
 Just the Flex to readjust yeah Symes?
symes
  • oxford
    • R reg 940 volvo
« Reply #73 on: 23 December 2012, 23:30:37 »
Yes mate Granddaughter will weld it for you no mate not joking she got modded welding helmet to fit her :y :y
Told you start them young-she nearly 8  :y
« Reply #74 on: 23 December 2012, 23:47:19 »
Flippin' Eck! that's tickled me pink symes! ;D
That kid will go far & no mistake! :y
Pages: 1 2 3 4 [5] 6   Go Up
