Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Bad running (Electrical or Mechanical)  (Read 8453 times)
Boggy
« on: 18 November 2012, 19:01:42 »
Hi guys,
 Me again with the ongoing problem :-P
 I Sorted the vacuum leak, twas the injector seals! anyway, I still have problems, Symes popped over to have a look and discovered a leaky exhaust! More on this in a Mo.
 When the car starts it runs lumpy but then sometimes it can tick over nicely just over 500RPM's. Driving it, well, you can accelerate away and it will change gear fine but then it seems to hold back, not as bad as last week when it was like switching the ignition off and then back on whilst driving.
 Now it just holds back usually around 2000RPMs. You can accelerate through it though but then it does it again, since last week, I havent used it on the main roads but it would go about 50MPH flat out! driven too hard it would bang and go into safe mode.
 Now back to Symes, He checked all Electrical connections and cleaned up the Throttle body including a blocked breather pipe. Now, the exhaust is blowing on the bendy join after the CAT and I will be replacing the pipe, this will mean I have a new CAT and probably get new LAMBAs. I have been reading up on symptons of the CAT and it ticks many boxes, the bad running, high use of petrol, lacking power on hills (on the level in my case)
 The EML is on, though I attempted to do the pedal trick but it did not work, however the EML went out, but the spanner light came on, this morning the EML came back on! I have a friend coming during the week with a machine capable of live readings. the pedal test as I say doesnt work nor does the paper clip test, Symes tried both. So, no codes as yet.
 On the plus side, I'm not ready to scrap her yet :P
Your views?
Re: Bad running (Electrical or Mechanical)
« Reply #1 on: 18 November 2012, 19:31:21 »
Hi guys,
Your views?
New cat not needed unless you`re prepared to pay in excess of £250 for a genuine one from VX read this http://www.omegaowners.com/forum/index.php?topic=109338.0
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 18 November 2012, 19:48:25 »
The engines holding back-missfire-1250rpm=2000rpm  ??? so come on somebody why cant do pedal test???? NOTHING HAPPENS  If I didnt know better thought rither blow on flexi pipe or MAF fault--ANY IDEAS+Dont be shy you lot BOGGY need us to heeellllllpppppp :y :y
« Reply #3 on: 18 November 2012, 19:50:29 »
read that post wrongly ... edited :)
If he can get from Oxfords to Swindon I'll put the maxscan on it .. but he might be nearer TB ??
« Last Edit: 18 November 2012, 19:52:40 by Entwood »
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 18 November 2012, 19:52:54 »
ENTWOOD mine is v6 For once its fine :o :o BOGGY got 2.2 four pot dbw
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 18 November 2012, 19:55:33 »
Bit iffy leaving street mate I drove it up road and back-no offence but she's not a happy miggy
Boggy
« Reply #6 on: 18 November 2012, 19:58:15 »
She's like an ex wife, after my money and won't do as I say :-(
« Reply #7 on: 18 November 2012, 20:20:10 »
Pedal trick won`t work on yours. Disconnect MAF see if there`s any difference, but a code-read is a must
« Reply #8 on: 18 November 2012, 20:22:20 »
As to why the pedal trick won't work ... answer in the first post ...  :)
http://www.omegaowners.com/forum/index.php?topic=90581.0
Boggy
« Reply #9 on: 18 November 2012, 20:39:02 »
Oh yeah, I remember reading that now. Still, I have a friend coming to see the car on Thursday night equipped with a diagnostic machine that takes live readings, proper garage type, should shed some light :-D exhaust should be here for Saturday, lamba sensors pending
« Reply #10 on: 18 November 2012, 20:40:23 »
If you mean the front downpipe with cat, hope it`s genuine VX
Boggy
« Reply #11 on: 18 November 2012, 20:55:18 »
Won't be genuine but if its not up to the job they can have it back! Failing that, I'll be onto trading standards!
« Reply #12 on: 18 November 2012, 22:49:30 »
Spend your money on getting the flexi replaced
Boggy
« Reply #13 on: 19 November 2012, 09:37:17 »
Where from? What size?
Boggy
« Reply #14 on: 19 November 2012, 12:02:00 »
Against my better judgement but on your advice, I have ordered a new flex,just hope it's £15 I shouldn't have spent :-/ we shall see. It's 51 by 100mm as per another post on this matter
Pages: [1] 2 3 4 5 6   Go Up
