Author Topic: what is it  (Read 1730 times)
Bob G
  • Gloucester
what is it
« on: 19 November 2012, 19:28:39 »
Poking around rear of engine tonight found walking shaped tube with a end that looks like it should be plugged in somewere, the end has a small hole in it, tried to take a shot but far to dark.  Could it be a breather of some sort?
2.0L GLS
Re: what is it
« Reply #1 on: 19 November 2012, 19:30:08 »
Yes, if it like the breather on the 3.0s it is an open pipe to do with the breather system.  It just floats around! ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: what is it
« Reply #2 on: 19 November 2012, 19:30:40 »
Auto gearbox breather assuming your's is auto ???
other rides
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: what is it
« Reply #3 on: 19 November 2012, 19:51:44 »
Bob G
  • Gloucester
Re: what is it
« Reply #4 on: 19 November 2012, 20:06:47 »
thanks although it is not an open ended pipe the connector?? on the end has a small 1/16" hole, pipe comes up near the centre rear and yes auto box.
Re: what is it
« Reply #5 on: 19 November 2012, 21:17:13 »
Then auto box breather 100% mate  :y
Re: what is it
« Reply #6 on: 19 November 2012, 21:44:13 »
1/16 pipe sounds more like a vac pipe to me, does it have a rubber half turn/joint on the end.
Auto box breather is closer to 8-10mm possibly even bigger
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: what is it
« Reply #7 on: 19 November 2012, 21:51:06 »
2.0L GLS
Do you mean 'walking stick' shaped? I misread initially, and indeed it does sound more like a vac pipe as MDTM says. Don't know anything about 2.0 engines though  :-X
Abiton
Re: what is it
« Reply #8 on: 19 November 2012, 22:02:48 »
You don't mean this dangly black thing on the black pipe hanging off the back of the EGR? (Near the rusty bits)
If so, it doesn't connect to anything.
Re: what is it
« Reply #9 on: 19 November 2012, 22:06:59 »
Whoops missed the bit about the connector and 1/16 hole - agreed autobox breather ~10mm o/d
Bob G
  • Gloucester
Re: what is it
« Reply #10 on: 19 November 2012, 23:20:55 »
Thats the one, thanks you did have to go and take it to take a photo ;D ;D ;D ;D  much appreciated.
