Author Topic: Bl**dy tyre mechanic...  (Read 4884 times)
Re: Bl**dy tyre mechanic...
« Reply #15 on: 21 November 2012, 08:48:01 »
The weight of an average sized bloke on the end of a metre bar produces about 600nm so I've been told....  :-\
accepting gravity factor as 10 and distance as 1 meter you get 60 kg per avg person.. thats nearly half of an avg OOFer ;D
Abiton
« Reply #16 on: 21 November 2012, 09:21:59 »
By my maths, assuming the bar is dead horizontal at the time, and the 'average sized bloke' has his centre of gravity exactly one metre from the centre of the nut/bolt being undone, 600Nm would correspond to a 9 stone 9lb person.  If that's average I'm fatter than I thought!
« Reply #17 on: 21 November 2012, 09:28:30 »
 ;D  I was that weight  at the age of 26 ;D
« Reply #18 on: 21 November 2012, 10:20:55 »
I know an old vx mechanic that still insists on putting all his weight onto the socket bar to tighten up the wheel nuts , and he's not exactly slim  ::)
« Reply #19 on: 21 November 2012, 17:18:21 »
89 kg .....according to the doctor. ;)
r1
  • nottingham
« Reply #20 on: 23 November 2012, 17:53:37 »
its so simple[if you fit and healthy] you get a new tyre fitted then when you collect it you check the nuts with the wheel brace provided if you cant undo them with it they are too tight!
« Reply #21 on: 23 November 2012, 18:01:06 »
Unless you are a weak woman like me and must use a long handled extension bar! ;D ;D ;D ;D ;D ;D ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22 on: 23 November 2012, 19:23:10 »
The infield method to tighten a Dakota prop nut is to hang an average weight person off a 6 foot bar and 'rap the end with a hammer'!
r1
  • nottingham
« Reply #23 on: 24 November 2012, 17:46:06 »
the point iwas trying to  make was if you cant undo them with the tools you have in the car then they are to tight ,if you carry that all the time then thats fine.
« Reply #24 on: 24 November 2012, 19:17:51 »
 :y :y
