Author Topic: indicators not working  (Read 4462 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 21 November 2012, 17:10:57 »
hi guys. As above mummy bear has reported that the indicators have simply stopped working. No other faults. Recently replaced a headlights bulb if that helps. Whats first port of call? Fuses? Cheers
RIP Paul Lovejoy
Re: indicators not working
« Reply #1 on: 21 November 2012, 17:12:26 »
...... Whats first port of call? Fuses? Cheers
Hazard warning switch ....... repeated switch it on & off or swap it with a known to be good switch.  ;)
« Reply #2 on: 21 November 2012, 17:43:23 »
About 20 times or so ;)
Webby the Bear
  • Northampton
« Reply #3 on: 21 November 2012, 17:44:12 »
oh. ok, wasnt expecting it to be that easy  ;D cheers andy.
those switches just pop out dont they? (like the boot release button)?
cheers
RIP Paul Lovejoy
RobG
    • 16 plate Mokka. Vivaro
« Reply #4 on: 21 November 2012, 17:53:56 »
cheers
Not the hazard one
« Reply #5 on: 21 November 2012, 17:56:14 »
Bit of a pig to get out ime. Havent yet mastered the technique. ::)
Webby the Bear
  • Northampton
« Reply #6 on: 21 November 2012, 17:56:25 »
cheers
Not the hazard one
thats jinxed for me saying ''that was easy''  ::) ;D
any idea how to remove/replace it?
RIP Paul Lovejoy
« Reply #7 on: 21 November 2012, 17:57:40 »
Back to you all knowing one. :D ;D
Webby the Bear
  • Northampton
« Reply #8 on: 21 November 2012, 18:01:37 »
 :o :o :o :o ;D
RIP Paul Lovejoy
RobG
« Reply #9 on: 21 November 2012, 18:10:57 »
Pop the front cover off and you`ll see the red "block" plus two lugs (top & bottom). Release both and pull out into cabin. May need a small screwdriver for the lugs as they`re sodding tight.
Have you checked the indicator relay and fuse in cabin fusebox
« Last Edit: 21 November 2012, 18:13:06 by RobG »
Webby the Bear
  • Northampton
« Reply #10 on: 21 November 2012, 18:13:01 »
Have you checked the indicator relay in cabin fusebox
Thanks Rob.... so its the little unit with the red block that needs replacing?  :y
RIP Paul Lovejoy
RobG
« Reply #11 on: 21 November 2012, 18:13:42 »
See my edit in above post re; fuse/relay
Webby the Bear
  • Northampton
« Reply #12 on: 21 November 2012, 18:15:06 »
no mate not yet. ill check those before i touch the hazard button. is this found on the steering column fusebox? :)
RIP Paul Lovejoy
RobG
« Reply #13 on: 21 November 2012, 18:17:18 »
::) ;D
Webby the Bear
  • Northampton
« Reply #14 on: 21 November 2012, 18:18:40 »
::) ;D
cheers mate  :y
RIP Paul Lovejoy
