omega drivers door stuck
Started by brassedoff, 21 November 2012, 19:09:12
brassedoff
Thanks for your help everyone!!!!! unfortunately had to take it into the garage....been looking at the latch as got the old one back.... there was quite a bit of play in it..know what to do the next time as I am sure there will be a next  time...The only thing is the sounder is in a strop!!!!!and is difficult to calm down, think I may have to disconnect..... ;)
Dont just disconnect it.Remove it. There have been several incidents where they have caught fire and burnt Omegas to a crisp after they have strted to give problems. :y
brassedoff
Interesting.....thanks for the info will remove :y can you tell me is the sounder playing up because the latch has been replaced...it seems to be something to do with the doors opening and closing..will not shut up.... then just stops....... also comes on when driving..could it be  a worn wire in the harness???  ::)
Usually it goes loopy when the internal batteries get low on power.Then the batteries leak across the circuit board causing a short circuit,which is where the fire comes in.
Doubt it would be connected to the door latch.
brassedoff
Thank you....they are robust cars and are great workhorses enginewise just keep going with plenty of inside space, cannot get anything the size to replace it thats why I want to keep it running as long as possible, this is number 11 vauxhall......   use mine for towing.... but the  electrics seem to let them down.... :y
brassedoff
Hi again......cannot use the car the sounder is  very erratic and frightened it starts sounding in the middle of the night!!!!!! took it into Evans  Halshaw who have phoned Vauxhall technical as they do not know what to do but Vauxhall have as yet not come back.....so I am back without a car this has all started since the new latch was replaced!!!!!!  (the central locking was disabled a while ago as it locked me out) dont know which way to turn...... :'(
Quote from: brassedoff on 30 November 2012, 19:14:03
As others have said just remove the power sounder, and replace with a new unit if required.
The garage do not seem up to it if they have to phone Vauxhall' technical on such an issue.
As for the central locking, why is it disconnected?  You can open the  drivers door with your key no matter what happens with the C/L.  Then get another Vx garage to reactivate the C/L and / or resolve any remaining issues with that and the latch. :y :y
Simples :D :D :D ;)
Guide for removing sounder.
http://www.omegaowners.com/forum/index.php?topic=90675.0
I have done it by just removing the screw and prising the scuttle panel up,then using a small ratchet spanner or socket.This saves removing the wipers etc,but there is a risk of breaking the scuttle panel as its plastic.
brassedoff
Thanks for the info guys.....evens halshaw is the local vauxhall dealership here!!!!!! have said I would take it back in on Monday...will have a talk to them then and see what happens.....think I could need a new sounder thinking of insurance......and will have the c/l put back...
brassedoff
Hiya Guys
Next instalment.....took the car into vx garage  as the sounder was not stopping at all and left it going mad.....apparently there was water in it so they dried it out but still did not work so disconnected it and left it in place having cracked the scuttle......I said I wanted it removed   but they assured me 100% it was safe, if I wanted it removed it was another £148.00....this weekend we are going to remove same, not taking any chances :y
Quotetook the car into vx garage
Quotethis weekend we are going to remove same
Why bother with a main dealer when your questions are answered here along with guides for DIY ??? ???
brassedoff
Hi our weather has been so bad that I asked them to  fit a battery for me and look at the other problem at the same time, as I was away....l thought it was quicker and did not want to leave it where it could be a bother :)
