Author Topic: Gearbox, diff & transfer box recommendations HERE >  (Read 1999 times)
oilman
  • Sunny Cornwall / UK
    • Opie Oils
« on: 22 November 2012, 15:06:56 »
Getting the right oil for gearboxes, diffs and transfer boxes can be tricky, so please ask here if there is any information that you need.
To help us to give the most accurate advice possible we do need some information about your car. e.g.
Make:
Model:
Year:
Manual/Auto:
Performance Modifications:
Driving style: (road / off-road / track etc.)
Any other information that may be relevant: e.g. approx BHP if modified, any transmission problems
What recommendation are you looking for? Gearbox, diffs, limited slip diffs, transfer boxes etc
Any oil we recommend is available to buy from us (if you would like to) for delivery throughout the UK and many destinations Worldwide. We offer a really extensive range of oils and lubricants from 11 major oil manufacturers at prices much lower than the high street and main dealers. We stock oils and fluids that meet pretty much all manufacturers and international specifications. Our brands include, Silkolene, Fuchs, Gulf, Castrol, Motul, Mobil, Millers Oils, Shell, Valvoline, Amsoil and Redline.
Plus, as the Club is a member of our club discount scheme you can get discounts of at least 10% across our entire range.
To redeem your 10% club discount simply use the following club discount code at the checkout.
OMEGA
Once the code is added at the checkout you will then receive your extra 10% club discount. However this discount code cannot be used in conjunction with other offer codes, BUT the code can be used in conjunction with any of our offers on this page HERE that do not require offer codes.
Any questions please ask here or contact us via email at sales@opieoils.co.uk
Finally, if there are any products we don't stock and you have difficulty getting hold of elsewhere, let us know and we'll see if we can stock them.
We look forward to being of help!
Cheers
Tim, Opie Oils
You can also contact us by phone on +44 1209 202944
(All oils recommended are available to buy online at my web site)
Use the code OMEGA and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk
email: sales@opieoils.co.uk - phone: 01209 202944
Re: Gearbox, diff & transfer box recommendations HERE >
« Reply #1 on: 22 November 2012, 18:17:17 »
Not sure it is the best place. But where is?
« Reply #2 on: 23 November 2012, 00:01:54 »
What would be recomended for LSD oil?
3.2 omega auto 2003 stock power.
A Common issue, of sorts, is the juddering in tight corners. Can this eradicated and still have a properly working LSD?
GM have additives etc, but can this be improved upon?
Thanks
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 23 November 2012, 12:10:02 »
I use redline oil in my diff,its got all the friction additives allready,will hunt a bottle out and put numbers up,, not cheap tho.
Hoof'land storeman.
jb
  • bucks
    • 3.2 Elite
« Reply #5 on: 24 November 2012, 07:04:04 »
I have done 2 cars recently to cure the judder on a tight turn- 1 with gm sae 90 and the little tube of gm friction modifier and 1 with Silkoline boa90ls which incorporates a friction modifier and is recommened for lsd diffs.
Results the same - judder eliminated . Why? because the friction modifier has reduced performance over time and I think that best practice is an oil change incorp friction mod every 50k or 5 yrs.
« Reply #6 on: 24 November 2012, 12:33:20 »
Yes it's been discussed on here before. Just wanted to add the oilmans view to it all. :)
biggriffin
Hoof'land storeman.
