Author Topic: Car not starting  (Read 2120 times)
Nick27
  • London
    • Omega 2003
Car not starting
« on: 24 November 2012, 16:02:07 »
Hi, car not starting, now i m confused whether its Battery or Fuel. as it had a range of 5 miles only. when turning the ignition to start switch off all lights on the dashboard and then when released it comes back. and sometimes it makes beep sounds.#
what would be the problem?
Thanks,
Re: Car not starting
« Reply #1 on: 24 November 2012, 16:03:37 »
A bit confused here.  Is the engine turning over? ???
If it does not, and the lights dim when trying, it is the  battery. ;)
Nick27
  • London
    • Omega 2003
« Reply #2 on: 24 November 2012, 16:04:37 »
nope, engine doesn't make any sound that it is starting!
Nick27
  • London
    • Omega 2003
« Reply #3 on: 24 November 2012, 16:05:28 »
yes the lights are dim. it has got Bosch Battery S5 with 5 year warranty
« Reply #4 on: 24 November 2012, 16:05:32 »
It most likely is the battery, and especially if the lights are dimming as you try
« Reply #5 on: 24 November 2012, 16:06:56 »
That is my experience anyway on all too many occasions.
Only once been a stuck air con pump!!  That is rare though ;)
    • 530D M Sport, 330i Coupe
« Reply #6 on: 24 November 2012, 16:44:35 »
Battery flat.
With a range of only five miles it mught be worth topping up with fuel from a can before trying to drive it anywhere with an incline.
Is it diesel or petrol, manual or automatic?
« Reply #7 on: 24 November 2012, 23:20:39 »
Thanks,
Pull out the powersounder and junk it mate - when ours packed in it ran battery flat. ;)  When recharged was ok
Oh and put some fuel in it before you try again ::)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #8 on: 25 November 2012, 09:26:28 »
Agree its battery related.
Jump leads linked to a donor car would resolve your curiosity. Sounds like battery though. Mine went flat a few days ago and that was just over four years old. Dash lights were normal until I turned the starter, which just about clicked, and then they dimmed right down. Fitted new battery and it's fine again now.
Reference the beep, it sounds like the power sounder is trying to go off due to sensing voltage change. I would remove it and bin it as said above.  :y
