air bag light
Started by plym ian, 26 November 2012, 20:50:46
plym ian
don't no if it is a problem but air bag light goes out when started but then comes back on for about 5 seconds then goes out, only noticed it does it in cold mornings don't know if that's anything to do with it or what the problem could be
grain.ben
I would think that maybe a Tech2 session, or you could try disconnecting the battery, wait 30 mins or so and reconnect
Need to see if any codes are stored. If so, note them, then clear them
Keith ABS
  I am asumimg that my airbag light will go out after a reset. the car was started and driven with all doors off in the paintshop.
Keith B
Should go out with a reset Keith. :y
I would have done it for you but my little device appears to have died. :(
Should do, assuming the work that has been caried out hasn't caused any faults :)
