Out side temp sensor
Started by amba, 28 November 2012, 21:33:31
amba
Dash display has been stuck on 12.5c for most of the day despite being sure it was much colder than that ::).
Tonight it changed down to 11.5c but this is still a long way off correct >:(
Does this sound like a new sensor is required or can the display be reset some how as have pressed end of steering column stalk but makes no difference.  :(
symes
mine started doing that then went minus ??? then went F
so got new sensor-still F
followed wiring back to multi plug ended up cutting plug off and soldering the wires together NOW fine :) :y
But that was my ******* silver shed aka miggy
Keith ABS
    I had the same problem. Corrosion of the multiplug teminals is the cause. they can be cleaned but may have to be cut and remade off if severe.
Keith B
