Author Topic: Diff removale question  (Read 1371 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 28 November 2012, 21:52:12 »
Ok Ive swaped a few diffs now, but that not the question. if I completely remove the diff without replacement, is the car still movable?, ie, it can still be moved, pushed or whinched on to a trailer without issues?, thanks Chris.
MarkC
  • Midlands, Derby
    • Signum, CarltonGsi3000
Re: Diff removale question
« Reply #1 on: 28 November 2012, 22:01:24 »
I'd say yes mate. The rear wheels will be free-wheeling so you'll be able to move it with no problems. Just make sure you remove (or at least tie-up) the half shafts hanging from each rear wheel and the prop shaft from the G/box or else they'll turn and slap about on the ground as you move the car.  :y
« Reply #2 on: 28 November 2012, 22:11:11 »
Definitely yes - as above. :y
zirk
  • Epping Forest
« Reply #3 on: 28 November 2012, 22:15:11 »
Thanks Mark and Albs  :y :y.
zirk
  • Epping Forest
« Reply #4 on: 28 November 2012, 22:18:12 »
Any one fancy a 3.9 LSD  :D :D ;D ok only joking, will be posted in FS Section if it gets removed on time,  :y
« Last Edit: 28 November 2012, 22:23:00 by zirk »
